MLS Masterclass 2006 CP Huntington FINALLY finished - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 06-24-2015, 01:57 AM   #1 (permalink)
Senior Member
vsmith's Avatar
Default MLS Masterclass 2006 CP Huntington FINALLY finished
No kidding! Sherman set the Wayback Machine for 2006;
When a fairly wet behind the ears still newbie kitbasher in large scale, who had previously only done a small number of relatively easy bashes decided to really test himself by doing the David Fletchers scratchbuild Masterclass project on MLS which was the CP Huntington 4-2-4.
Now I was learning ALOT with this terrific class but halfway thru building I found that the design wasn't going to work that well on my R1 curves, the rear swung WAY out and hit things YIKES, what to do, I had to veer off the program and improvise. My decision was to cut off the bunker, move the cab forward and build a 4-2-0 teakettle. First was modifying the chassis thus:
Once I was pretty sure it worked I moved forward with the rest of the build:
Then built up the boiler and cab:
With that I moved it along to a certain point of finished work:
And that was pretty much where I left it at about 2007, when my indoor layout became an on and off again affair I just kept this as a display model. I was very proud of this as it was my first more or less true scratchbuild. my first attempt at running it on the pizza were a failure, it keep jumping the tracks and jamming into the scenery. So I left it as display item:
And thus its been since.
__________________
Have Fun With Your Trains!
vsmith is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-24-2015, 01:59 AM   #2 (permalink)
Senior Member
vsmith's Avatar
Default
Until today...
I decided that if that after much violence and bloodshed, some of my other large models now run on the pizza I would give this one another try. This time I systematically figured out where each problem was and fixed it, usually with unspeakable violence to the layout. Also I remounted the tender latch for the drawbar, the main reason it was jumping the tracks turned out to be not it hitting the side of the layout, well that too, but that the standard LGB loop had a raised ridge on its inside that would catch the drawbar hook, ride up on it jamming it and triggering a derail. Once I cut it smooth (and did unspeakable violence to the layout) it now runs well on the layout ....in ONE direction, I'll take that as a success... :-)
One I had it working I decided to raid the parts boxes and add some last missing details and give the whole thing a nice shiny glosscoat! Here she is finally finished after a short lull of oh..8 years ;-)
I'm still looking for a few harder to find details I'll add as I go but she's done and ready to pull a short string of Lil Haulers at the shows!
__________________
Old 06-24-2015, 02:14 AM   #3 (permalink)
Senior Member
vsmith's Avatar
Default
Oops! I just realized that the challenge was in 2005! So its been dang near 10 years since I started the project!
__________________
Old 06-24-2015, 11:34 AM   #4 (permalink)
Super Moderator
East Broad Top's Avatar
Default
Looks great! I've got a few passenger car projects that are coming up on 10 years not being finished, so now I don't feel too bad.
Later,
K
East Broad Top is offline   Reply With Quote Quick reply to this message
Old 06-24-2015, 06:21 PM   #5 (permalink)
Dwight Ennis's Avatar
Default
Looks great Victor! Good job!!
Dwight Ennis is online now   Reply With Quote Quick reply to this message
Old 06-24-2015, 08:06 PM   #6 (permalink)
Senior Member
placitassteam's Avatar
Default
There is a lot to be said for persistence! Congratulations on a sweet little engine.
__________________
Winn Erdman Steamaholic 291
placitassteam is offline   Reply With Quote Quick reply to this message
Old 06-25-2015, 12:31 AM   #7 (permalink)
Senior Member
Richard Weatherby's Avatar
Default
I will admit to a Hunington Doozie project that has been sitting on a shelf for 20 years.
__________________
Dick http://www.mdlsrs.com/MarylandCentral
Richard Weatherby is offline   Reply With Quote Quick reply to this message
Old 06-25-2015, 11:24 AM   #8 (permalink)
Senior Member
vsmith's Avatar
Default
Thanks guys, I'm just glad I can start to enjoy using it now. Going thru the roster, as I've more or less officially run out of space for new projects, I'me going to go back over everything to evaluate its usage, and make any necessary changes plus weathering/detailing. I'm getting tired of looking at all these half finished projects.
__________________
Old 02-13-2017, 11:54 AM   #9 (permalink)
Senior Member
vsmith's Avatar
Default
To whom it may concern, due to circumstances beyond my control (Vertical Scope screwing the pooch and deleting 80MB of my photo history three months ago with no resolution) This and all other threads of my 10+ years of activity on this site are now closed, if you are curious please look to my identical threads on LargeScaleCentral which in the coming months I will attempt to re-edit photos into from my personal archives once I have a new storage site up and running. It was fun while it lasted but the collective of monkeys now running this site now have soured my experience. Have a good day.
__________________
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Masterclass 2007- Finished Porter models! David Fletcher MasterClass & Articles 22 06-24-2016 12:21 AM
Masterclass 2005 CP Huntington Model Building. David Fletcher MasterClass & Articles 14 06-11-2014 01:55 AM
C-19 Conversion Finally Finished rhyman Model Making 8 09-06-2011 12:20 PM
FINALLY finished my Mallet! Mik Model Making 19 05-29-2010 11:11 AM
MLS Masterclass - Finished Models Showcases David Fletcher MasterClass & Articles 11 03-28-2009 08:33 PM
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
