Battery/RC in the Lionel BN GP20 w/sound - Page 3 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 02-16-2017, 01:03 PM   #21 (permalink)
Seņor Member
Greg Elmassian's Avatar
Default
Mike a few comments:
In post #17 you talk about swapping trucks to regain better short hood operation, so I guess that is where you decided to swap them, but nothing changed according to post #20.
So, it would infer that nothing wrong with trucks. Could it be as simple as inadequate power combined with more lamps running forwards than reverse? (less currend drawn in reverse due to fewer lights, thus better running?)
My opinion is that the pack you are using is wrong for G if it tops out at 12v, and the MRC 9500 is rated 30VA, so 2 amps draw at full throttle would be maxing it out pretty much. Also, never trust meters in an inexpensive system until you check them with another meter.
Another item: the pulse power "goes away" around 5 to 6 volts on the output, so if you have heating of the motors, you most likely have a different issue.
__________________
Be sure to visit my site, lots of technical tips and modifications, and you can search for topics and key words.
Note: Due to the history of acrimony from some members, I might stop responding in a thread, so feel free to ask me questions via email (not private messages).
PLEASE NOTE: I have disabled Private Messaging, please use regular email: greg@elmassian.com
Sponsored Links
Advertisement
Old 02-16-2017, 07:16 PM   #22 (permalink)
Senior Member
Mike Toney's Avatar
Send a message via Yahoo to Mike Toney
Default
You misunderstood Greg. The motor over heat issue was on another engine that didnt like PWM power. That was years ago. My point about the running better one way than the other is that the problem lies in the onboard Railsounds electronics. There is only 1 bulb differance between foward and reverse direction. The speed vs voltage needed is way more than just what a bulb would consume. Yes the transformer is underpowered, but it gives a baseline and it will run the engine in either direction for as long as I want and not overheat the transformer. Its only a temporary set up. I think the next step is to eliminate the factory sound, and just tie the lighting circuit to track power(its not constant lighting) and the motors right to the track pickups and see how she runs. Atleast by not needing the PWM to Linear board, I save almost $100 off the cost of the RC stuff. Wish someone else made ready to use Prime Stratolite beacon circuit(not a kit) other than Richmond controls. His stuff is great but a huge waiting list. Mike
__________________
Silly NT's...I have Aspergers.
SA#16
Mike Toney is offline   Reply With Quote Quick reply to this message
Old 02-16-2017, 08:35 PM   #23 (permalink)
Senior Member
Mike Toney's Avatar
Default
Ok, I gutted the electronics, found some burnt parts on the lighting board, so I lost the beacon on the lead unit so I removed the stand alone beacon board from the dummy engine for now to restore the roof beacon on the lead unit. In the pic below, we can see the culpret for the high amp draw in foward direction. Mike
__________________
SA#16
Old 02-16-2017, 11:37 PM   #24 (permalink)
Seņor Member
Default
Wow, well that sure could be the issue... congrats on digging in and finding it.
__________________
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
On the hunt for a Lionel large scale BN GP20 Mike Toney Beginner's Forum 11 06-15-2015 07:08 AM
Lionel GP20 motors train man Rolling Stock 8 08-25-2014 01:45 AM
Lionel RTR Battery operated G train sets Tim Hytrek RC/Battery Operations 10 12-08-2009 10:19 AM
Searching for a pair of Lionel LS BN GP20's Mike Toney Beginner's Forum 6 09-09-2009 11:32 PM
Sound for Lionel Thomas Shay Gear Head Sound Systems 9 07-14-2008 08:26 PM
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
