Sound setup for a-b-a usa f3
4K views 34 replies 6 participants last post by  artgibson
#1 ·
I am installing Airwire drop in in all three units a-A-B-A. iam installing Phoenix p8 in the two A units.
My question is" What shud I deactivate in seconded A unit. Visa v horn etc.
I know it is possible over kill but think it might increase battery life.
Thanks in advance.
#3 · (Edited)
With Airwire and Phoenix you would only need to shut off the bell and horn in the B unit. I'm assuming you are going to use the consist feature of the Airwire and that you have a T5000 transmitter. If set up this way only the A unit that is the lead unit will repsond to a bell or horn command. By pushing reverse and consist the transmitter will reverse the consist automatically making the other A unit the lead. Only the lead unit in the consist will repond to function commands which would also include hot box recording,cab chatter,etc. I use this Airwire feature all the time. It works really well. The manual explains how to set up a consist. I really don't think battery life would be affected.
#6 ·
Paul
When I set the enigines up, A_B_A number one engine is in forward position, number two in forward
how do I put the third engine so that it is reverse.
Do iopen each engine seperately and have one engine opened at at time until ready to run consist.
Am I making sense?
#7 ·
When setting up the consist in the transmitter I don't think it would really matter if the locos are on or off. If any units are reversed from the lead unit, you just need to push reverse after adding the address for that loco. The transmitter will then know that those units are reversed. After a little practice and maybe some frustration it will all come together. I can't emphasize enough about reading the manuals and just trying it. Nothing will break.
#10 ·
Gbis Paul is the guru of airwire so do as he says. I have one other way that i do it. I like to here the horns from all the locs. So what I do is make the locs. have all the same number they run so close that i pulled over 50 cars and if i want to run one in reverse i change cv 29 to 3 on that loc.
#11 ·
Changing CV 29 to 3 is only for short addressing.
It is better to state that you need to change CV29 by 1 to reverse an engine but that does assume the odd bit is not set.
With many DCC systems you can read cv29 before writing it.
I use long addressing with 128 speed steps thus I need to change cv29 original value of 38 to 39.
#13 ·
It's too bad that Airwire does not support advanced consisting, so this issue would be a no-brainer.
Come to think of it, maybe the Phoenix does not support advanced consisting either.
It seems that universal consisting is the best way to go here, the way described by Paul.
Using basic consisting as Dick has outlined does have a lot of limitations unless you want all sounds from all locos.
I have a basic explanation of Airwire consisting here:
http://www.elmassian.com/dcc/specific-manufacturers/airwire/airwire-programming
#14 ·
Greg,
I don't want to dreail this thread but I was a little disappointed in the T5000 consisting. I thought that only being able to set up one at a time would be a problem but for me it has worked out since I really don't have anything that I want to leave in a permanent consist anyway. I like to mix and match and once you are used to the setup procedure it goes pretty quick.
#15 ·
Yeah, funny it could not have more than one consist memory.
It's definitely better than no support, or forcing Basic Consisting where you have to reprogram the loco addresses to be all the same, thus requiring reprogramming to run separately.
I love assembling the lashup, drive the locos together and then consist and take off.
I like sound a lot, and many of my diesels have multiple speakers and the roar of a consist like an ABBA sounds great taking off.
#16 ·
I have read the manual 20 times and have used the instructions on page 25 for getting addresses. I follow instrutions to the letter. When I have finished with the last # I find no instrutions as what follows. Do I just hit spr key.
I find no instrutions then to open that engine up.
I am trying fellows. I can run all three on address 3, just nedd to fine out how to reverse the third unit, All three ar f3 usa and each has dropinn decoder.
Thanks for your help.
Art
#17 ·
Dick, if you are using addresses from 1 to 127 (99 for some systems and MTS is 8 or 22), these are short addresses and the engine number is in CV1.
Long addressing has the engine address in CV17/CV18 and CV 29 has an additional bit set.
My CV 29 is set to 38 in DCC giving me 28/128 speed steps and long addressing.
My Xmas engine is 1225 (Dec 25th). So CV 17 is 196 and 18 is 201. (you must add 192 to CV 17 in decoder addressing).
#20 ·
Dick
I think I am going to try it today with same address. I cannot seem to get the decoder and throttle to hold a different address than the 3.
Can I make a consist with all engines address as 3?
Thanks for your help. Taking this old mind a long time to understand cv's and such.
Regards Art Gibson
#23 ·
Thanks Dick
I am going to Mall to run trains. If nothing else I will just run AB today.
I do hear beeps but does not seem to hold. Will try on track, I have been using rollers and free standing.
Will make video and share what I have.
#25 ·
This might sound dumb but I have done it myself. After you change CV1 to a new address in the decoder don't forget to actually address the loco in the transmitter. # address #. Otherwise the transmitter will still be sitting on the old address.
#26 ·
Well went to Mall and ran just the ab units address 3. Tried everything in manual and it did beep and I did put in address on transmitter but nada.
I dont thinkl I had full charge on engine with the sound board and ran full tilt with a lot of horn blowing and ding dong's and had about two hour run.
Getting ready to upload video to youtube and will be available later at theis thred.
Have ordered 5000 transmitter ,hopefully it will work.
I did try with all three units and did not get the decoder to talk with the 9000 transmitter.
#32 · (Edited)
I WILLtry it that way. On page 25 it shows ans I quote, "Now push 1 then 1 then * again.' May be a typo.
Thanks
Art
Okay Dick. When all else fails try something different.
I used only one 1 in process and guess what?. It works. Just a simple solution as you suggested. I thought I had tried the One 1 in sequence but guess I had not.
Okay next weekend, on to greater things.
Thanks a lot guys for your help with this thread. Really makes things enjoyable at Mall noot just going around in circles.
I now have five of my pieces of equipment in service.
Regards Art
#34 · (Edited)
Dick I have been away and missed your remark.
How do I change cv11 back to 0.
BTW I was at Mall today and for some reason the engines would not respond to throttlr as fas as speed was concerned. The sound would be at faster pace and motors barely moving. What have I done wrong.
I was using t5000 today trying to set up consist.
Sorry to be so much trouble.
Art
Hold on I just reread the manual and found out what the "VALUES" meant for the program. They used and example of 1234 and that was what was slowing the engine down. ****, I learned something new tonite.
Art
My wife says I am getting senile.
#35 ·
Building consist
Keith Stratton took my ABA units to his house over the weekend to change out the couplers and installed Kadee couplers in all three to make it eaier to hookup. USA knucle coupler from the F-3 is lousy.Would not hook up with the USA passenger cars and Keith fixed that. No easy job but Keith is a genius with the conversions.
BTW , after he fixed them up we set the engine out on track, I had each programmed separtely and they follwed each other around his great layout. I stopped them went to #7 on T5000 and programmed to original factory setting and built a simple all # consist and boy did it run and loook great going around his track.
Maybe too simple but it worked and no problem programmimg.
First day we have has sunshine in a long time.
Regards Art
