How do you install a LGB 65004 Sound Box? - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 01-30-2017, 05:33 PM   #1 (permalink)
Junior Member
Default How do you install a LGB 65004 Sound Box?
I purchased a LGB 65004 Sound Decoder to put in my LGB 24430 Electric Loco. I have installed these before in other engines and usually can do it in 15-30 minutes.
My problem is I can not figure out where the power leads (0-24 v DC) from the sound unit should attach to the basic motherboard or the power leads coming off the current pick up wires from the two motors.
Nothing on the engine logic board replicates the voltage I am giving the drive trucks, and even the leads off the drive trucks have less than 1/2 the voltage I am delivering to the wheels/pickup shoes.
I have already spent 3 hours trying everything and am totally stumped!
Any ideas?
Thank you!
Randy
psu76 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-30-2017, 10:10 PM   #2 (permalink)
Junior Member
Smile Resolved an unexpected issue with the sound install
After trying various other solutions, I decided to give it my best shot by attaching the LGB 95004 to the brown and white leads off the power pick up wires. After putting it all back together, I tested it on my main line, powered by a LGB 10 amp Jumbo transformer - everything worked as advertised! It turns out my one amp transformer on my test bench had insufficient power for everything in the LGB 24430 engine: 2 motors, 12 lights, two pantograph motors, the charging of the LGB 65011 power capacitor, and the sound unit! (This is all on an analog layout.)
The instruction sheet states you need at least a one amp transformer to run the sound box. I thought "check, I'm good there!" Even after reading the entire instructions 5 times I didn't think the instructions were probally written for a single motor engine...
Problem solved! I thought I would share it in case someone else runs into this same issue!
Old 01-31-2017, 07:40 AM   #3 (permalink)
Senior Member
Default
Not enough power seems to be a common issue in largescale.
2 motors, lights, sound with super caps or batteries charging, pantographs all add up quickly. And do not forget for track power the possibility of bumpers with lights.
I have 8 amp minimum for both my DC and DCC supplies on my various layouts.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
sound card install into lgb tender question jerryld Beginner's Forum 2 08-22-2015 07:03 AM
Aristo U25B Sound & Battery Install oceansidean Beginner's Forum 5 03-22-2011 10:17 PM
first R.C. box car install RCE RC/Battery Operations 2 06-06-2010 09:06 AM
Help With GE Dallee Diesel sound card install krogerssolar Sound Systems 10 06-26-2009 10:28 AM
Which sound unit to install? stevequatro Product Reviews 15 06-11-2008 01:56 PM
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
