Need Pacific parts - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 12-31-2019, 10:58 PM   #1 (permalink)
Senior Member
pimanjc's Avatar
Send a message via AIM to pimanjc
Default Need Pacific parts
I help keep the Botanical Gardens trains running. We are in desparate need of old style #3 driver axle/gears for two Aristo Pacifics. If anyone has the complete running gear for an oldstyle or newstyle Pacific I would be interested if it isn't too expensive.
I would also be interested in running gear [or parts] for both LGB and Aristo Makados [2-8-2].
Contact [email protected] if you can help.
__________________
"Never promise more than you can give. Always give more than you promise." ~JC
"You don't stop laughing because you grow old, You grow old because you stop laughing." ~AU
Charter Member of the Roundhouse Irregulars
pimanjc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-01-2020, 05:12 PM   #2 (permalink)
Greg Elmassian's Avatar
Default
Nice to see you post JC! I'll look around, but these parts are definitely at a premium. Very few old ones out there with good drivetrains, and few new style Pacifics, I guess they were not as popular as the Mikado.
__________________
Old 01-02-2020, 05:59 PM   #3 (permalink)
Senior Member
Default
You might check with Rex Ammerman.
__________________
Paul Burch
Sierra Cascade & Pacific R.R.
Gig Harbor Washington
Paul Burch is offline   Reply With Quote Quick reply to this message
Old 01-02-2020, 06:36 PM   #4 (permalink)
Senior Member
Default
Hi Jim,
I know nothing about Aristo Pacifics, so forgive me for asking but I am curious, when you say "old style #3 driver axle/gears" was it all not part of the chassis, or is this just the gears to one driving wheel axle.
Are there not 'other' gears that would fit?
Cheers,
David Leech, Delta, Canada
David Leech is offline   Reply With Quote Quick reply to this message
Old 01-02-2020, 08:34 PM   #5 (permalink)
Senior Member
Michael Glavin's Avatar
Default
JC,
The old/early Pacific's used a drive that was less than perfect, They were NON modular as the newer drives are. If memory serves me; the early Pacific drives share the same Engineers plastic axle gears as their early diesel motor blocks i.e., U25, FA's, RS3 and such.
If you don't have any luck, PM me, I have parts buried somewhere in a container out back or inside the hangar up high on pallet racks. In either situation I'd have to go on a mission to locate said parts... Sounds like a worthy cause, given some time I can help if you strike out herein.
Michael
Michael Glavin is offline   Reply With Quote Quick reply to this message
Old 01-03-2020, 03:45 PM   #6 (permalink)
Senior Member
Pete Thornton's Avatar
Default
David, on the old pacific the motor was under/in the firebox over the rear truck and drives the back (#3) axle. I assumed JC had chewed up his gears. (The later versions used a modular axle/gearbox on every axle.)
Sounds like Michael thinks there are. If the FA gears fit there must be dozens of them lying around!
__________________
Pete Thornton is offline   Reply With Quote Quick reply to this message
Old 01-04-2020, 04:06 AM   #7 (permalink)
Default
axles 1 and 3 are both driven
__________________
Old 01-04-2020, 12:07 PM   #8 (permalink)
Senior Member
Default
Quote:
Greg, surely that is the later version with the 3 separate gearboxes? I'm sure mine was only driven on the rear axle.
__________________
Old 01-05-2020, 07:55 PM   #9 (permalink)
Default
Uhh...
1. right side is a gearbox...
2. middle is hollow, no worm on shaft
3. left side has no box
The new units have all identical gearboxes in white plastic:
They have hex drives, and flywheels between the identical gearboxes..
This is a picture of a mikado/articulated block, I don't own an Aristo Pacific, just worked on my friends ones...
You can see the flywheels between the gearboxes, the motor is at one end of the motor block.
Hope this clears the confusion.
__________________
Old 01-06-2020, 02:10 AM   #10 (permalink)
Senior Member
Default
FWIW:
The left or rear axle-driver is housed in the motor block, is hard fixed in place and driven by driveshaft/spur/worm. A cover or cap is removed in the pictures above.
The center driver floats vertically.
The forward axles gear box articulates and is driven by driveshaft/spur/worm.
Michael
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
