Re-wheeling USA trains motor blocks - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 03-19-2008, 02:24 PM   #1 (permalink)
Member
Default Re-wheeling USA trains motor blocks
Hi,
Has anyone done this? As far as I can tell the wheels must be shrunk/pressed on - I haven't tried a puller on them yet, it looks like a one-way experiment, but the only options seem like either that, and hope not to damage the axle, or cut the wheels off (and hope not to damage the axle..).¬* Then there's fitting the new ones..
Jonathan
jonathanj is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-19-2008, 08:15 PM   #2 (permalink)
Senior Member
Paul Norton's Avatar
Default RE: Re-wheeling USA trains motor blocks
Each half axle is pushed straight into the sleeve on the pinion gear, but it is a very tight fit. The fit is so tight it is not unusual to see a split in the gear sleeve. Unfortunately that will allow the axle and wheel to slip under load. Over time the axle will work its way out of gauge, wobble and cause derailments. If you can turn a wheel with your fingers, the gear sleeve is split.
I repair mine with monofilament fishing line and Super Glue. When replacing the axles, there is a stop in the sleeve so the wheels are evenly spaced and properly gauged.
__________________
Paul Norton
Ottawa Valley GRS
Paul Norton is offline   Reply With Quote Quick reply to this message
Old 03-20-2008, 02:22 PM   #3 (permalink)
Member
Thanks - If I need to repair any, at least I know how to now.¬* Looks like voluntarily changing the wheels (I had some nice 38mm 10-spoked ones, with con-rods, in mind) is a non-starter, it'd be easier to start fresh..
Thanks again.
Old 03-23-2008, 11:30 AM   #4 (permalink)
Greg Elmassian's Avatar
A short note: Pressing the USAT train half axles all the way in will result in a tight or even out of spec back to back gauge.
I strongly suggest using a set of calipers to achieve your desired back to back.
I have a page listing all the NMRA and G1MRA specs that might be of help:
http://www.elmassian.com/index.php?o...d=85&Itemid=95
__________________
Old 03-23-2008, 04:47 PM   #5 (permalink)
Art
Greg is correct. I have about 40 USA locos and 99% of them the gauge is correct, but I do have a few that with the wheels pressed all the way into the axle they are to tight back to back. So watch what you do or you will have problems at turnouts for sure.¬*
Art
Art is offline   Reply With Quote Quick reply to this message
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
MOTOR BLOCKS John J Rolling Stock 8 01-20-2013 07:24 PM
Aristo U25-B Motor Blocks docwatsonva Rolling Stock 1 10-25-2012 06:45 PM
Swaping Motor Blocks John J Rolling Stock 6 04-25-2010 08:56 AM
K line GP 9 motor blocks myline Model Making 2 01-22-2009 02:54 PM
USA GP-38 Motor blocks Joe Mascitti Model Making 11 12-07-2008 07:42 AM
