Size comparison of parts for 1/20th scale and 1/13th scale - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 02-08-2014, 09:56 AM   #1 (permalink)
Senior Member
Amber's Avatar
Default Size comparison of parts for 1/20th scale and 1/13th scale
I recently bought a set of 2 axle car journals from an ebay seller to see if they were large enough to be used for 1/13th scale (7/8ths scale) cars. They were listed as "large journals" and were bigger than the quarter used for size comparison in the picture. I have a set of 7/8ths scale wheels that I bought a while back that are too small for my 2 inch scale projects, so I decided to use them to build an ore car in 7/8ths scale. I also have a set of 7/8ths scale link and pin couplers that I had bought from Ozark Miniatures to see if they would work for 2 inch scale, and they were much too small for that application.
The wheel journals that I got from ebay seem to be about right for 7/8ths scale, they would be way too big for 1/20.3 scale. I took a picture of the journals and link and pin couplers, as well as 1/20th scale car journals and link and pin couplers from Hartford Products for a size comparison. The big journals come from Wiseman Model Services, through ebay. They were reasonably priced.
I thought it would be an interesting size comparison.
Amber is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-08-2014, 09:58 AM   #2 (permalink)
Senior Member
Amber's Avatar
Default RE: Size comparison of parts for 1/20th scale and 1/13th scale
The Wiseman large journals are not listed as being 7/8ths scale, but I would say that they would work quite well in that scale.
I plan on building a wood ore car in 1/12th scale with the parts, I don't have a 7/8ths scale ruler, but I do have a 1/12th scale ruler. That makes it easier.
Old 02-09-2014, 07:21 AM   #3 (permalink)
Senior Member
Pete Thornton's Avatar
Amber,
There are a number of suppliers of 1" scale equipment, intended for the 5" gauge ride-on market. 1" : 1 Ft =1:12, so they are very close to 1:13.7, or 7/8ths scale.
So are Doll houses - most are 1" scale! All those lamps, chairs, and rugs will fit your caboose!
__________________
Pete Thornton is offline   Reply With Quote Quick reply to this message
Old 02-09-2014, 10:14 PM   #4 (permalink)
Senior Member
Amber's Avatar
I've looked at several websites with 1 inch scale parts, but they're always more expensive than 7/8ths scale parts, and most of the 1 inch scale parts are designed for standard gauge equipment. Generally speaking, the parts are bigger than narrow gauge parts. The car that I plan on building with these parts will run on 45 mm gauge track, roughly 2 foot gauge.
The wheels and journal boxes for 1 inch scale trains on 4-3/4s or 5 inch gauge are rather expensive, beyond my current means.
I might only build this one 2 foot gauge ore car, just to use the parts that I have. If it works out well, I might be persuaded to buy more 7/8ths scale wheel sets and parts for another car or 2. :-) At least I have a drawing for this car, unlike my larger cars that I'm not getting anywhere on. It's based on the ore cars of the Iron Mountain Mining Company of western Montana. It's a 2 axle drop bottom wood frame car.
Old 02-10-2014, 12:28 PM   #5 (permalink)
Senior Member
The Pine Tree journals were made specifically for 7/8ths and are no longer available. The others are small but will work ok for 7/8ths. Size in the real world is a rubber band.
Noel
__________________
Noel Crawford
livesteam5629 is offline   Reply With Quote Quick reply to this message
Old 02-11-2014, 12:45 AM   #6 (permalink)
Senior Member
Amber's Avatar
I drilled out the axle holes in the big journals this evening, to a size "F" drill, very slightly larger than 1/4 inch. The nylon bushings wouldn't quite fit in the 1/4 inch hole that I had drilled it out to. I drilled the holes because they were oversize for the axles on the wheelsets that I have, and the original holes had an upward angle to them instead of being straight. Odd hole arrangement. Anyway, I put 2 bushings in the holes, one bushing fits inside the other and the smaller one is the right size for the axles on the wheelsets. I had to get the journals set up so that I could determine the width of the frame on the car. Then I cut the wood frame parts to suit the spacing for the journals and the axles.
It looks like these journals will work quite well for my purpose.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New 1/20th scale projects Amber Model Making 30 10-30-2013 12:11 AM
Locomotive Size comparison SteveC Public Forum 3 05-05-2012 08:13 AM
Scale Comparison Illustration Matt Vogt Model Making 7 03-04-2009 07:10 PM
Euro scale 1/20th ??? GN_Rocky Public Forum 12 08-25-2008 09:52 AM
Bachmann size comparison Richard Weatherby Product Reviews 7 03-05-2008 05:39 AM
