Oil's Well That Ends Well. - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 11-23-2008, 07:35 PM   #1 (permalink)
Mik
Senior Member
Mik's Avatar
Send a message via AIM to Mik Send a message via MSN to Mik
Default Oil's Well That Ends Well.
As I mentioned in the building forum ( http://www.mylargescale.com/Communit...c/Default.aspx ) I planned on building a gas well to put along the back edge (about 3" wide ledge) so that it would block the fact that the world simply, well, ends. Then I thought a bit more, and decided to make a small oil well instead. I originally envisioned something along the lines of a 4HP Myrick Eclipse with attached pumpjack, but I didn't have the proper sized dowel for the cylinder....Soooo, then I made do with what size I had (3/4") , and found a couple spare cast iron toy wheels and ended up with something about the size of a 10HP. Rather large for this type of installation, but Star made vertical engines this size for in well drillers, so it will do. I'm still trying to decide whether to make a shanty for over it. If I had to do over I'd make the engine a little shorter. The beam is kind of cozy with the top of the hot tube on the engine. The valves are just brads... I was too lazy to model the springs. And the cooling barrel should be higher for a thermosiphon, or it should have a small centrifugal pump on the bottom pipe..... But that is getting kind of picky for a background item.
How it looked about 3 hours ago. One nice thing about being indoors is you can use basswood without worrying about it warping.
Painted and installed
Comments, suggestions, ideas all welcome.
__________________
Mik
Allegheny Valley, the outside, inside, inside, outside railroad..
http://www.the-ashpit.com/mik/layout.html Out of my mind -- back in 5 minutes.
Mik is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-23-2008, 08:32 PM   #2 (permalink)
Senior Member
Default RE: Oil's Well That Ends Well.
Looks Great Mik! I may have to make something like that. Thank for posting it.
__________________
Aaron Loyet
Silver Creek & San Juan R.R.
Loyet Logging Company
trainbuffjr is offline   Reply With Quote Quick reply to this message
Old 11-23-2008, 09:51 PM   #3 (permalink)
Mik
Senior Member
Mik's Avatar
Here's a slightly different view.
A 4HP Myrick would be about 4 feet tall and the beam about 6 feet long...as you can see by the figure, mine is rather larger, lol.
__________________
Mik
Old 11-23-2008, 10:54 PM   #4 (permalink)
Senior Member
San Juan's Avatar
I like it
I recently built a Walthers oil well for the HO layout, and may build a second one since the first one turned out great. Here's a link to a photo
__________________
Matt
Anaheim, CA & Bayfield, CO
Click Here for photos of my train layouts
San Juan is offline   Reply With Quote Quick reply to this message
Old 11-24-2008, 05:17 PM   #5 (permalink)
Senior Member
Ray Dunakin's Avatar
Pretty nifty!
__________________
http://www.raydunakin.com
Ray Dunakin is offline   Reply With Quote Quick reply to this message
Old 11-26-2008, 03:08 PM   #6 (permalink)
Les
Senior Member
Les's Avatar
Mic,
I liked it so well I swiped a pix for my files.
You're probably aware of this, but at an engine show (I used to show those) I saw a coolant tank that had a brass mesh top. It was shaped like an inverted funnel. The water came out of the engine thru a pipe and tended to run down the mesh screen, gaining air-cooling, then was caught at a rim at the foot of the funnel and sent into the tank, below. I never did get around to building one for myself.
Les
Les is offline   Reply With Quote Quick reply to this message
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oil in Boiler csinc Live Steam 13 03-20-2011 12:23 PM
(Re)Used Steam Oil? Dr. J Live Steam 18 08-21-2009 07:07 AM
HAGRS 09 Report: Odds and ends (*PICs) Steve Stockham Large Scale Events 11 08-18-2009 06:25 AM
Bar Oil for Steam Oil? Jerry Barnes Live Steam 82 10-22-2008 06:34 PM
Cricket MK II production ends mkrion Live Steam 1 08-24-2008 10:14 AM
