track power connector spacing - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 04-25-2020, 10:14 PM   #1 (permalink)
Junior Member
Smile track power connector spacing
I am in the planning stages of rebuilding my outdoor garden layout. I haven't had trains outside for over 3 years now, since I HAD to finish deck first.
I am planning on a rectangular layout with 2 mainlines. the outer one being 10' diameter curves and the inside with 8' diameter curves. I do not anticipate running streamlined passenger cars, only coal trains and a small LGB passenger set.
How far apart should I place my track power connections? My backyard area is 40' x 20'.
Any assistance would be greatly appreciated.
Thank you,
Mike McCaffery
mikey802it is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-26-2020, 02:05 PM   #2 (permalink)
krs
Senior Member
Default
Mike,
If you use good solid connections between the track elements, either soldering or rail clamps, you really only need a single power feed unless you want to set up different power sections to run multiple trains in analog.
The conductivity of code 332 brass track is much better than even 12 gauge copper wire.
The idea of multiple power feeds comes from the H0 modell crowd where that is needed for a larger layout; it is also a possible requirement if you use stainless steel code 332 track depending on the size of the layout.
But not necessary for code 332 brass or nickel-plated brass track.
PS: I used to have a nice bar chart to illustrate the conductivity of code 332 brass and the various AWG sizes of copper wire but can't lay my hand on it right now.
krs is offline   Reply With Quote Quick reply to this message
Old 04-26-2020, 09:22 PM   #3 (permalink)
Senior Member
Treeman's Avatar
Default
Krs is correct, brass is a very good conductor. The failure would be joints from rail to rail. I usally suggest running a feed to the far point of your layout. Low voltage landscape wire will do the job, #12 will reduce voltage drop.
__________________
Mike
Reindeer Pass Garden Railroad Supply
Treeman is offline   Reply With Quote Quick reply to this message
Old 04-26-2020, 11:06 PM   #4 (permalink)
Member
KeithRB's Avatar
Default
Will my brain says you are correct, the more conservative engineer in me says that 3-4 feeds is a good plan.
KeithRB is online now   Reply With Quote Quick reply to this message
Old 04-27-2020, 12:51 AM   #5 (permalink)
Senior Member
Default
Quote:
If th track is a better conductor than the wire, doesn't it make more sense to run the feed wire to the nearest point and let the track carry the current to the farthest point?
If the current has to go though 250 feet of track, anyway, doesn't it make more sense to go through 250 feet of track and 20 feet of wire, rather than 250 feet of track and 50 feet of wire?
Also, the further you run the wire, aren't you more likely to accidently cut through it when gardening, or whatever?
toddalin is offline   Reply With Quote Quick reply to this message
Old 04-27-2020, 08:08 AM   #6 (permalink)
Junior Senior Member
Ironton's Avatar
Default
I think the far point feed is a second feed. It is just in case there is a break in the continuity at a rail joint, the second feed would send power backwards through the section that would otherwise be cut off.
Also, when there are two breaks it will make it easier to locate them. Start an engine at each end and when it stops you know you have a bad connection at that area.
__________________
Rich Black
Northwest Indiana
SA #269
Ironton is offline   Reply With Quote Quick reply to this message
Old 04-27-2020, 12:12 PM   #7 (permalink)
Senior Member
Naptowneng's Avatar
Default
I have had good track power performance on my 180 ft of 332 brass track with one power tap and track clamps, either Aristo or Split Jaw. But I put in one more tap half way around, and it did not seem to make any difference. Keeping the tops of the track clean is more important in my experience. Pollen season does not help.....
Jerry
Naptowneng is offline   Reply With Quote Quick reply to this message
Old 04-27-2020, 04:36 PM   #8 (permalink)
krs
Senior Member
Default
Bottom line is that the power feeds required in Large Scale depend on the particular layout configuration and what wishes to accomplish.
Reading Mike's original post, it sounded to me like he was thinking of the smaller scales like H0 and N where power feeds are required at regular intervals. That's because the cross-section of H0 and N scale rails is small and therefore conductivity is poor. That is not a problem in Large Scale at all - because of the large cross-section of code 332 rail, the conductivity of that track is better than what one would get with the heaviest copper wire people would use.
The only exception to that I can think of would be a very elongated dog-bone layout where a second feed to the return track at the centre would make some sense because the second power feed cable would be very short.
Running a second power feed cable to allow for power fed "backwards" in case there is one poor connection would only apply to a point-to-point layout - in a typical loop layout which Mike's seems to be, one poor connection wouldn't matter since power is fed automatically in both directions.
And I finally found the bar graph that shows the resistance of brass and stainless steel code 332 track compared to copper wire - it's attached.
Old 04-27-2020, 04:39 PM   #9 (permalink)
Greg Elmassian's Avatar
Default
Yes, first questions should have been:
what brand of track and metal
sectional or flex (number of joints)
clamps, stock joiners or bonded (soldered jumpers)
Then a good answer can be given. For the size you have, with clamps, or joiners in like new shape from LGB and grease in the joints, I'd put 2 feeds per loop.
The metal of the rails is irrelevant in most cases, it's the joints between sections.
__________________
Old 04-28-2020, 08:23 AM   #10 (permalink)
Senior Member
Default
When I built my RR I did a figure 8. My power connection is to the 90 degree cross over on 2 of the 90 degree sides. I now feed both loops of the figure 8 from both sides of the 90 degree crossover thus eliminating the need for additional feeders. Note I only run approx. 50 feet for dogbone end to end with the crossover about midpoint, others have a much longer run and would need additional power connections. 15 years, no issues.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
