Battery backup for irrigation system - Page 2 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 10-15-2016, 06:17 AM   #11 (permalink)
Senior Member
John J's Avatar
Default
Why not use a battery back up system like one would use for a computer? We use to use one to run cooling fans on a Inferred Dryer if there was a power failure. When the power failed the battery back up ( USB) from a computer would run the fans to cool the lamp cases.
JJ.
__________________
John J is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-24-2020, 05:06 PM   #12 (permalink)
Junior Member
Default
Hello there, when we utilize our U8903a with ethernet remote, at that point a similar estimation, we can do likewise from the front board gives us an altogether different outcome. Generally substantially more clamor and THD is estimated utilizing ethernet, than measure it from the front board. Is there any known issue with an answer for this, we could utilize? much appreciated, tamas
primpwrsolution is offline   Reply With Quote Quick reply to this message
Old 04-24-2020, 05:21 PM   #13 (permalink)
Senior Member
Default
I installed a "whole house" generator panel (10 breaker 15,000 watts) and the garage, housing the sprinkler controller, is one of the switchable circuits. So, if I switch on the generator, such as during a brown out in the heat of summer, the sprinkler system works.
(Don't neglect the garage. Though possible, it makes it hard to get the car out if the opener has no power.)
Obviously, if I'm not home, there is no one to connect and turn on the generator, but we're always home.
Panel connection to main breaker panel:
60 foot 6 gauge x4 conductor cable to generator:
Generator stored in garage by back door:
Generator in position. Part of the engine and the exhaust sit outside:
toddalin is online now   Reply With Quote Quick reply to this message
Old 04-24-2020, 09:47 PM   #14 (permalink)
Greg Elmassian's Avatar
Default
Quote:
So a U8903a is an audio analyzer, which indeed can measure THD (Total Harmonic Distortion)
But using the audio analyzer remotely with a battery backup or UPS would probably work.
If this is what you are asking, you do need to look at the power consumption, and determine the size of UPS required.
__________________
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Most common type of battery/battery car plug? Cougar Rock Rail RC/Battery Operations 20 07-14-2012 05:20 PM
Irrigation system installation Mike Reilley Gardening & Landscaping 16 05-18-2011 03:26 PM
Battery Car/with Battery Charging Circuit Madstang RC/Battery Operations 16 02-26-2011 03:44 PM
What Battery RC system do you recomend? dms1 Beginner's Forum 63 06-22-2010 08:33 PM
Battery operation/battery charging via track power silvercity RC/Battery Operations 42 11-15-2009 04:44 PM
