Tank Engine #3 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 05-23-2018, 03:07 PM   #1 (permalink)
Senior Member
steamermeister's Avatar
Default Tank Engine #3
I've had my mini lathe for about 15 or 16 years but it wasn't until recently that I finally got a mill. As such, this is intended to be a "getting to know you" project for the mill. The lathe also has received numerous upgrades over the past year so it was high time to test it out. Also, I wanted to become more familiar with the basics of locomotive scratch building. Though there are plenty of locomotive plans out there that are built around oscillating cylinder engines, this is not what I wanted to do. My own view is that the scope of work concerning oscillating engines is very limited and does not lend itself to any higher knowledge of how other, more prototypical styles of locomotive engines work, namely slide valve and piston valve types. I started doing as much research as I could on the subject while simultaneously searching for a set of plans. Something serious but manageable for a beginner to locomotive building.
The design I am building is ostensibly a Dacre, a project locomotive originally proposed by Peter Jones. Though I was unable to find original Peter Jones plans, I've gathered that the initial design was less of a scratch build than an exercise in assembly and integration using as many off the shelf parts as possible, mostly Roundhouse. My own build is based on the work of Erik-Jan Stroetinga whose AutoCAD drawing I found here (http://www.john-tom.com/html/SteamPlans3.html). All that is required to open the file is a DWG viewing program, which are available free online. That said, in order to better understand the locomotive and to document the changes I wanted to make, I decided to produce my own set of plans which I will share freely when they are more ready.
I will be showing the build from the beginning, with as much detail as is appropriate. The first parts will show everything in excruciating detail but towards the end I will be skipping over steps that are easily assumed. This first post however, is towards the end of the chassis build. Enjoy!
steamermeister is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-23-2018, 03:08 PM   #2 (permalink)
Senior Member
Default
Old 05-23-2018, 06:01 PM   #3 (permalink)
Senior Member
bille1906's Avatar
Default
Congratulations
It runs wonderfully in both directions
__________________
Bill Allen
Woodside CA
bille1906 is offline   Reply With Quote Quick reply to this message
Old 05-23-2018, 06:48 PM   #4 (permalink)
Senior Member
placitassteam's Avatar
Default
A very nice start. You are showing great machining skills. I see that you are using slip eccentric valve gear. My only mostly scratch build is a Mason Bogie which I posted on MLS. I think the details are on the archives. I will be looking forward to watching your progress.
__________________
Winn Erdman Steamaholic 291
placitassteam is offline   Reply With Quote Quick reply to this message
Old 05-23-2018, 08:07 PM   #5 (permalink)
Senior Member
Default
Thank you, the valve timing still needs work. This video was shot yesterday after setting the valve events. Currently only the chassis has a complete design. Not that I haven't given thought to the rest of it.
Old 05-23-2018, 08:57 PM   #6 (permalink)
Senior Member
wigginsn's Avatar
Default
Very nice. Also liking your choice of beverage, I trust it assisted during any musing moments you had..
Cheers
Neil
__________________
Tuahiwi Valley Lumber 2008 - 2012 (RIP)
Tuahiwi, New Zealand
wigginsn is offline   Reply With Quote Quick reply to this message
Old 05-24-2018, 06:40 PM   #7 (permalink)
Senior Member
Default
Thanks, a victory beer was in order. Until the air test it was difficult to know whether I was making functional parts, or just converting raw stock to scrap metal.
I've made my drawings available via this link: https://drive.google.com/drive/folde...SM?usp=sharing
There is still more I want to add to the chassis drawing but the stuff that is there is complete and correct, or at least as correct as anything self checked can be. In any case, access to the drawings will make my photos easier to follow.
Old 05-24-2018, 06:41 PM   #8 (permalink)
Senior Member
Default
Old 05-24-2018, 07:31 PM   #9 (permalink)
Senior Member
bille1906's Avatar
Default
Your new mill looks like the one I just purchased with just a few things different
What brand is it?
__________________
Bill Allen
Woodside CA
Old 05-24-2018, 10:04 PM   #10 (permalink)
Senior Member
Default
My mill is a Precision Matthews PM-25MV. At work we have a Grizzly G0759. Both mills are excellent and are probably the best hobby class milling machines available. While shopping, I saw this video which swayed me towards the Precision Matthews.
Hindsight being 20/20 neither is perfect and the video left out a number of faults with the PM, although a compelling argument could be made that the PM is technically better. For my part, I had to make a number of superficial modifications to make the PM more user friendly and my own opinion is that the perfect mill would be a mix of both machines. Doom and gloom aside, you can't go wrong with either one.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thomas the Tank Engine... steamtom1 Live Steam 5 03-31-2015 04:53 PM
Aster Kraus Tank Engine Joe Johnson Live Steam 2 05-19-2014 08:24 AM
Bachmann 0-4-0 side tank engine R/C refit project Amber RC/Battery Operations 17 05-06-2012 07:10 AM
Thomas Tank Engine set for $107?? JackM Public Forum 6 07-30-2011 07:07 AM
Interesting article on W.V. Awdry, author of Thomas the tank engine vsmith Public Forum 2 01-11-2010 06:38 PM
