Heritage Midwest Steam engine - REPAIR question - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 05-07-2020, 09:35 AM   #1 (permalink)
Senior Member
scoobster28's Avatar
Default Heritage Midwest Steam engine - REPAIR question
I finally finished my BAGRS engine yesterday and ran it for the first time. However, the silicone tubing that I used fit so tightly over the cylinder "spigots" (input/output tubes) that it pulled the input one completely out of the cylinder casting. I don't know if they were press fit, Loctited, or what, but it is now loose. When I ran the engine yesterday it seemed to work fine but it dribbled water out of the hose connection to that input despite having the clamp on.
Can anyone comment on whether there is a way to secure the input barb back in place? Thanks.
__________________
"One cannot learn to swim without getting his feet wet" - Benjamin Maggi
scoobster28 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-07-2020, 05:37 PM   #2 (permalink)
Senior Member
Default
Which engine do you have?
the Heritige Engine or the one that needed to be assembled?
Steve
Steve Ciambrone is online now   Reply With Quote Quick reply to this message
Old 05-07-2020, 06:21 PM   #3 (permalink)
Senior Member
Default
The assembled Heritage engine.
__________________
Old 05-07-2020, 07:09 PM   #4 (permalink)
Junior Member
Default
If it was my engine , I would clean the barb fitting and the location where the fitting goes into the engine and use Red Loctite to secure it. Red Loctite will not come loose again without a large application of heat to remove the fitting. I have had to use a heat gun to remove nuts and bolts for my work process and Red Loctite takes about 550 degrees of heat to break things back down. Should hold things together very well for your process.
I built a BAGRS locomotive some years back, great fun and a very smooth runner. Enjoy.
Charles M
CharlesTrains is offline   Reply With Quote Quick reply to this message
Old 05-07-2020, 07:44 PM   #5 (permalink)
Senior Member
bille1906's Avatar
Default
Red Loctite is a strong thread lock but for this application, I would use a Loctite retaining compound. I use 680 or for superheated steam lines 620 is a higher temp but not quite as strong
__________________
Bill Allen
Woodside CA
bille1906 is offline   Reply With Quote Quick reply to this message
Old 05-08-2020, 08:21 AM   #6 (permalink)
Senior Member
Default
I have access to Loctite 680 so I will try that. I can't use much, as if ANY excess gets in there it will lock up the piston. Thanks.
Old 05-08-2020, 10:26 PM   #7 (permalink)
Senior Member
rwjenkins's Avatar
Default
Quote:
If you're worried about locking up the piston, take the cylinder off before applying the Loctite, and put it back on after it has dried.
__________________
rwjenkins is offline   Reply With Quote Quick reply to this message
Old Today, 02:23 PM   #8 (permalink)
Senior Member
Default
As suggested, I removed the cylinder and then cleaned the area with lacquer thinner. Some Loctite 680, a 24 hour wait period, and that thing is in for good. And slightly less water seepage from the area now. Thanks.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
