Converting Bachmann body-mounted knuckles to hook-and-loop? - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 12-29-2019, 03:51 PM   #1 (permalink)
Member
Default Converting Bachmann body-mounted knuckles to hook-and-loop?
I have a Bachmann flat car that came with body-mounted knuckle couplers. It also came with hook-and-loop parts, but they're meant to screw on to the trucks (not an option with this car).
Is there a correct way to make this conversion? I was able to use parts of the knuckle assembly to attach the hook-and-loops at the correct height/location, but it feels like more of a hack than an intended option.
__________________
eatrains is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-29-2019, 06:05 PM   #2 (permalink)
Senior Member
Pete Thornton's Avatar
Default
You must have a Bachmann Spectrum 1:20.3 flatcar. [I think they had fake wood bits through the turnbuckles underneath, which the old Big Hauler cars did not.]
I doubt they ever intended that you would fit the hook-and-loops, but if the parts made it work then you are in great shape. Just don't try to get it to go around R1 curves!
If you do have R1s or something like the 4' diameter, I would advise that you sell the car and buy the other version, which has truck-mounted couplers.
__________________
Pete Thornton is offline   Reply With Quote Quick reply to this message
Old 12-30-2019, 03:13 PM   #3 (permalink)
Member
Default
The car came with a log skidder on top and was billed as a Big Hauler, but the car has metal wheels so maybe they used a Spectrum car in a big hauler box? https://shop.bachmanntrains.com/imag...cale/95699.jpg
In any case, there's enough play in the screw that the hook freely swings to the left and right on tighter curves, though it doesn't spring back to the center.
__________________
Old 12-30-2019, 06:50 PM   #4 (permalink)
Senior Member
Default
Aha - the famous 20' "shortie" cars. Yes, not a Spectrum, though these were billed as 1:20.3 which we quickly discovered was a crock as they scale out at 20' in 1:22.5.
If you want to experiment, the Bachmann Parts store sells the trucks for a mere $8.40. I bought some to use under a railtruck.
You could add a wide brass bar from the pivot, bend it to fit over the crosspiece (to keep it solid with the truck,) and bolt the coupler to the bar.
__________________
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
