DCC and Battery power - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 12-16-2011, 03:33 PM   #1 (permalink)
Junior Member
Default DCC and Battery power
So after the confusion with the smoke units I now have this quandry.
I have just purchased a Zimo MX695KV decoder/sound card and was planning to have the loco run under battery power, reason being that for now I will only be running one unit and battery power is cheaper than track power in this case.
I was under the impression that I could purchase a NCE G wire Pro Cab R along with a Quantum G Wire Receiver, the receiver would connect to the Zimo in the Loco and away I go.
I was just talking to a supplier and he informed me that the G wire will not work on battery power as True DCC is through the track. He also said that each manufacturer will only work with their own transmitter/receiver so for example an NCE transmitter would not work with a Digitrax receiver or vice-versa, which seems to negate the purpose of the NMRA standards.
I would appreciate if someone could confirm that I can use battery power for the G wire and that different manufacturers with the NMRA standard will work together.
Regards
Colin
bcbrit is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-16-2011, 05:36 PM   #2 (permalink)
Senior Member
Totalwrecker's Avatar
Default RE: Battery power
Too bad you didn't put DCC in the subject box, most who know may not see this because those folks don't like (said with a smile) batteries!
Bear in mind the older I get the less I know...
I think Airwire is battery compatible, but it isn't full DCC. I think the rest of the DCC stuff does play nice together.
Read the previous threads in the DCC forum, your answers are there if you want to look for them.
Good Luck
John
__________________
Happy Rails,
John
His friend Jerry Dillon looked up at the hillside and said; There is a big ledge, and the whole damned hill is a total wreck with quartz boulders of ore.
Totalwrecker is offline   Reply With Quote Quick reply to this message
Old 12-16-2011, 06:17 PM   #3 (permalink)
Senior Member
blueregal's Avatar
Send a message via Yahoo to blueregal
Default RE: DCC and Battery power
The G-wire, as far as I know will only work with a QSI decoder, and the NCE gwire cab will work with QSI/Gwire, on either track power or battery, I have several units set up this way, and I use a NCE Gwire cab, and also an Airwire t-9000 throttle which also works with the QSI/G-wire also. Greg E. will most likely see your post and he is a very knowledgeable person on DCC
blueregal is offline   Reply With Quote Quick reply to this message
Old 12-16-2011, 07:26 PM   #4 (permalink)
Greg Elmassian's Avatar
You might be able to get it to work, the gwire receiver has been adapted to a lenz dcc decoder.
It's a case of feeding the dcc signal from the gwire receiver into the right spot on the Zimo, and then powering the zimo track inputs with a battery.
Problem is you have to find someone who can figure this out.
It might be possible but there's inexpensive track powered DCC systems...
Look to the future, limiting yourself now might be more expensive in the long run.
__________________
Old 12-16-2011, 07:28 PM   #5 (permalink)
Super Moderator
East Broad Top's Avatar
You're not exactly "up the creek," but the G-wire receiver will not work for you (unless you can hack it per Greg's line of thinking). I think if you want battery powered, wireless R/C of your Zimo decoder, your best (perhaps only) bet will be Airwire's G-2 board, and connect the Zimo to the aux. DCC outputs of that board. My understanding is that this is a universal DCC output that's compatible with any DCC decoder. Airwire designed it to work with DCC sound systems, but I can see no reason why you can't hook the Zimo decoder up to it and also use the Zimo's motor drive as well. The big limiting factor will be that the DCC output is rated at only 3 amps, so you'll want to make sure your loco draws under that.
I have not tried running a DCC motor control decoder off the Airwire board personally, just DCC sound boards. But in theory it should work. I wish Airwire (or anyone) would come out with a simple generic R/C receiver that would be compatible with any generic DCC motor/sound board.
Later,
K
East Broad Top is offline   Reply With Quote Quick reply to this message
Old 12-17-2011, 01:23 PM   #6 (permalink)
Senior Member
Axel Tillmann's Avatar
Without having the detailed documentation at hand I can only say I suspect there might be another way to get this done.
Connect Battery + and Minus to the + and Minus of the decoder and connect the G-wire stuff to DCC track input. But first try the 3A wire direct DCC port.
__________________
Axel
Axel Tillmann is offline   Reply With Quote Quick reply to this message
Old 12-17-2011, 04:43 PM   #7 (permalink)
Junior Member
Thanks for all the input,
Rather than get myself in too deep at this point I think I will go with DCC track power, obviously I'm not familiar enough with DCC to start modifying/adapting anything. Doesn't hurt to go for it but I do tend to get ahead of myself.
Regards
Colin
Old 12-17-2011, 07:41 PM   #8 (permalink)
In the long run DCC track power is the cheapest, once you are over 4-6 locos, the cost for remote control cannot be beat, and the functions are beyond all the other systems available, mainly because of all the "goodies" we inherit from the smaller scales, where it is the dominate remote control system.
__________________
Old 12-18-2011, 07:16 AM   #9 (permalink)
Senior Member
Frankly speaking - good move.
As Craig already says, cheaper and more functionality. And if done right (track laying) you will not experience the hyped up power connectivity problems that some fear mongers try to portray.
__________________
Axel
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help Please..Brand New FA-1 runs fine on Battery Power but won't budge with track power. DERRILLV Beginner's Forum 4 11-03-2013 03:51 PM
DCC for track *and* battery power? Scottychaos DCC in Large Scale 20 03-03-2011 09:33 PM
Battery operation/battery charging via track power silvercity RC/Battery Operations 42 11-15-2009 04:44 PM
Battery power for Bachmann 44-tonner power block Bill Martinsen RC/Battery Operations 13 11-01-2008 11:23 PM
Combining DCC with Battery Power StanleyAmes DCC in Large Scale 1 04-26-2008 02:21 PM
