What wire for LED headlights - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 08-11-2012, 10:36 AM   #1 (permalink)
Senior Member
Default What wire for LED headlights
I am trying to figure out what wire I can use for LED's, from the LED to the source. This would be for applications that would require soldering to the LED leads and running it either externally (as in a headlight housing on a Steam Loco, or lighting that may require bending the wire).
Thank you.
noela is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-11-2012, 10:59 AM   #2 (permalink)
Senior Member
dbodnar's Avatar
Default RE: What wire for LED headlights
Posted By noela on 11 Aug 2012 10:36 AM
Thank you.
Noel - I have used very small gauge wire with LEDs, as thin as 28 gauge. If I am only operating one LED I have even used "wire wrap wire" that is 30 AWG. If the wire is going to be bent from time to time make sure that you use stranded wire - solid wire can only be bent a very limited number of times before it fails.
In situations where wire is going to be bent over & over I use wire that is intended for connections between meters & probes - it is designed to be bent and abused quite a bit. It is called Test Probe Wire.
dave
__________________
Dave Bodnar
email: [email protected]
web page: http://www.trainelectronics.com
dbodnar is offline   Reply With Quote Quick reply to this message
Old 08-12-2012, 12:53 PM   #3 (permalink)
Greg Elmassian's Avatar
another fine gauge wire that is designed to be flexible is "Litz wire" you can search for it.
Also, if you are doing this on live steam, get teflon insulated wire.
the bottom line is you can use fine gauge wire since you are running low current.
__________________
Old 08-14-2012, 07:06 AM   #4 (permalink)
Senior Member
Thanks Greg,
I always appreciate your expertise.
Noel
Old 08-14-2012, 07:53 AM   #5 (permalink)
There was also the type of wire used in the old record players, very fine and thin, to run out to the tonarm, and had to be light and flexible so no force was added to resist the tonearm following the groove, but can't find the reference to it, i.e. specific name.
There's other tricks, which you may not need, like live steamers often run a single wire, and use the metal chassis as a ground.
On the LEDs, recently I've used some flat topped LEDs for marker lights, which spread the beam out a bit more.... they are often used in outdoor christmas lights, but they are appearing more and more on the aftermarket in 3m size.
__________________
Old 08-15-2012, 08:20 AM   #6 (permalink)
Senior Member
aopagary's Avatar
Posted By dbodnar on 11 Aug 2012 10:59 AM
If the wire is going to be bent from time to time make sure that you use stranded wire - solid wire can only be bent a very limited number of times before it fails....
http://www.ripley-tools.com/PDF/Mill...structions.pdf
no argument with stranded being more flexible, but most of the time a solid wire fails is due to a nick made when stripping the insulation. for solid, wire-wrap size gauges, i always use NO-NIK wire strippers.
aopagary is offline   Reply With Quote Quick reply to this message
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Headlights on live steam Zonk Live Steam 6 07-19-2012 07:36 AM
LED Headlights & Fitting John R RC/Battery Operations 7 04-25-2012 05:11 PM
RED WIRE , BLACK WIRE ?????? smcgill Rolling Stock 13 11-06-2011 03:26 PM
Want to add headlights to my F-40 vsmith Model Making 7 10-23-2008 11:44 AM
Looking for headlights ohioriverrailway Model Making 8 10-21-2008 10:44 AM
