Best battery for old Sierra Sound from Soundtraxx - Page 4 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 12-10-2014, 02:45 PM   #31 (permalink)
Senior Member
Default
It looks to me that that battery charges at ~ track voltage and you control the current to the battery to keep from overpowering it, similar to the way LEDs are done.
If the battery can approach the track voltage, even current reduced, I would think you would want a supercap capable of withstanding this voltage. You may need to series 9 caps for the necessary voltage and would still want some resistor in there to limit the current.
toddalin is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-11-2014, 02:44 PM   #32 (permalink)
Senior Member
trainstrainstrains's Avatar
Default
So I would measure my max track voltage and install supercaps in series adding up to the same or greater voltage and install a resistor between track and supercaps. Is this correct?
trainstrainstrains is offline   Reply With Quote Quick reply to this message
Old 12-11-2014, 03:11 PM   #33 (permalink)
Senior Member
Default
Sounds right.
Also as a point of reference, with the track voltage at max, measure the voltage across the battery terminals before installing anything.
Old 12-18-2014, 09:04 PM   #34 (permalink)
Senior Member
Default super supercaps
I've installed three 2.7 10f supercaps in series for the Sierra on my Aristo-Craft 2 8 8 2 mallet's tender as toddalin suggested , great stuff, really super happy about it, thanks todallin.
PS first time image upside down, do not know for what reason.
Old 12-18-2014, 10:31 PM   #35 (permalink)
Senior Member
Default
Another satisfied customer.
Old 12-18-2014, 11:57 PM   #36 (permalink)
Senior Member
Default
Very difficult to program the shuff rate with the + & - buttons on the Sierra , a little erratic timing on the shuffs Dont think it has anything to do with the supercaps, probably the RR Concepts StationMaster I'm using , or dirty not very well connected track. Probably bests to synchronize it to the wheels.
Old 09-18-2015, 01:13 PM   #37 (permalink)
beavercreek's Avatar
Default
I know that this is an old thread but I wonder if the original posters might be still available?
I have quite a few Soundtraxx Sierra boards that were being used in my locos ( or ready to be installed) when I was totally DC analogue.
I always had problems with batteries (forgetting to turn off, forgetting to charge, having to replace 'dead' lead acid gel ones and so on).
Now that my layout can have DCC/DC/Battery and live steam, I have been replacing a lot of the Sierra boards with DCC sound boards (such as ESU, Massoth etc).
But I also have some plain motor DCC decoders and also some Locos that will remain DC. I will also have a couple or three, of the Sierras, on battery locos with the Aristo Revo system.
This is where the Sierra boards will be used. I have made up some Supercap boards and they work fine....well sort of.
The real problem with them is that you do not get the start up sounds and it can be hard to sync the motion for the first initial chuff speed as the board is 'popping' until more voltage is supplied to the rails while the caps charge up, which of course increases the chuff and also the rate of movement of the loco.
Once the loco is in motion they are great and bad spots on the track or switches are overcome happily just like with back-up batteries.
Standing sounds are also just as they should be.
So I have found a solution...connect the on/off switch, that came with the Sierra kit (or any SPST switch) between the capacitors and the board on one of the leads (positive is the preferred method but t doesn't really matter).
When you are finishing a session with the loco....turn off the switch to the caps when they have been charged after running (run for a bit if the loco has been standing for a timeand the caps are discharged).
When the loco is put on the track for the next session. turn on the power supply voltage so about 5 to 6 v and then switch on the caps....voila...starting sounds and a loco that can be synced for chuff and movement if wished.
beavercreek is offline   Reply With Quote Quick reply to this message
Old 09-18-2015, 02:22 PM   #38 (permalink)
Senior Member
Default
Nature of the beast, but worth the trade-off. Only happens when you are starting and the caps are discharged..., which can actually be everytime if you let it "idle" long enough for them to discharge.
When others discuss putting resistors and diodes in the path to the caps to limit the current when they are discharged, I say it just prolongs this "agony" because the boards seem to be robust enough to take the momentary current draw of the discharged caps.
If you can find a Phoenix "Big Boost" add-on, you can get the caps to charge/stay charged down to ~3.5 volts, well before the engine moves.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sierra Soundtraxx Pete Thornton Sound Systems 4 10-02-2012 04:48 PM
Soundtraxx Sierra Manual StanleyAmes Sound Systems 5 09-05-2011 10:58 PM
Sierra Soundtraxx Boston Maine Mike Sound Systems 3 03-05-2011 12:48 PM
Can Sierra Soundtraxx be reprogrammed? rreiffer Sound Systems 17 06-06-2010 10:05 AM
Battery for Sierra sound Doug Bowman Sound Systems 1 03-01-2010 04:33 PM
