Installing LED headlights - Page 2 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 10-30-2018, 10:00 PM   #11 (permalink)
Senior Member
Default
Does anyone have a wire diagram to use the CL's with LED's???
bdp3wsy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-31-2018, 04:27 PM   #12 (permalink)
krs
Senior Member
Default
Quote:
Check the data sheet - the middle lead is not connected
https://www.mouser.com/datasheet/2/2...8A-1021782.pdf
krs is offline   Reply With Quote Quick reply to this message
Old 11-01-2018, 07:57 AM   #13 (permalink)
Senior Member
Default
Be sure to tie them to dc voltage in series with the led/leds.
I wire 3 leds in series to the CL2-N2 (some engines have 3 headlights). Also, these are digital and have V+ at 24 volts so I could have 6 in series if needed.
Old 11-08-2018, 08:24 PM   #14 (permalink)
Senior Member
Dick Friedman's Avatar
Default
I have stopped using resistors too. The CL2 limits current, and work for anywhere from one to a dozen LEDs in parallel. Yes, they cost more than resistors, but for me, the ability to use them anywhere for any number of LEDs make them much more useful.
__________________
Garden Railroad IS fun, it really IS!
Dick Friedman is offline   Reply With Quote Quick reply to this message
Old 07-20-2020, 02:10 PM   #15 (permalink)
Member
Default Installing LED Headlights
What LED do you favor for headlight use?
And for battery power you would hook up the CL2 in front of the ESC, so that there would be constant VDC & Polarity to the lighting, right?
WES
NW AZ
gizmorama is offline   Reply With Quote Quick reply to this message
Old 07-20-2020, 04:24 PM   #16 (permalink)
Greg Elmassian's Avatar
Default
There's millions of different leds, normally pick a "warm white" for a diesel, and a yellower one... they are cheap, buy a few and see if you like them.
The CL2 should only have the LED on it, you seem to be asking to power the entire esc...
The CL2 sets a constant CURRENT, not voltage.
__________________
Old 07-20-2020, 08:49 PM   #17 (permalink)
Member
Default Installing LED headlights
Hmmm? I imagined the CL2 in parallel with the ESC input so it would always have the same polarity and supply voltage.
Old 07-21-2020, 06:33 AM   #18 (permalink)
Senior Member
Default
The CL2 is a 20 milli-amp limiter and you need to be careful to not use a single 10ma led.
I used 2 10 ma identical leds in parallel with a cl2 with no problem. Also as I am DCC i sometimes put 20ma leds in series. This can make for simple wiring.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
What wire for LED headlights noela Beginner's Forum 5 08-15-2012 08:20 AM
LED Headlights & Fitting John R RC/Battery Operations 7 04-25-2012 05:11 PM
Did Oil Lamp Headlights Flicker? DKRickman Railroad Operations 6 01-07-2009 03:30 PM
Want to add headlights to my F-40 vsmith Model Making 7 10-23-2008 11:44 AM
Looking for headlights ohioriverrailway Model Making 8 10-21-2008 10:44 AM
