Returning to G-Scale. Need a little help! - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 02-10-2020, 09:34 AM   #1 (permalink)
Junior Member
Default Returning to G-Scale. Need a little help!
Hey everyone. New here. Recently my love for trains came back swiftly and started taking over my brain. I loved LGB when I was a kid and want to return to it now in my late 30's. I'm selling my ATV and gonna begin my G Scale journey again. But there is a lot of things I have not seen before and just have some questions.
So I wanna use LGB but I see PIKO makes 1:22.5 engines now. How is the quality? I was looking at 37243 DB IV BR50 Steam engine cause I love big boy lookin steam or the LGB Mikado.
Also I noticed MTH makes the exact big boy steam engines i love but they are 1:29. Can these even link up with LGB and if they can does the size difference look odd together. I just cant find a side by side pic of them.
Those are the two questions I was having issues finding answers for. Any help would be great. Thanks!
-Rich
Wr3ckage is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-10-2020, 09:49 AM   #2 (permalink)
Junior Member
Default
I should also add I currently still have my LGB stuff. So I'm only interested in getting Piko, MTH and LGB engines and using it with my LGB cars.
Old 02-10-2020, 01:36 PM   #3 (permalink)
Senior Member
Pete Thornton's Avatar
Default
Rich,
I'd suggest you do a few searches for scale comparisons. MTH are quite good 1/32nd scale models of standard gauge locos. They look small compared with USAT or the now defunct Aristocraft.
LGB and Piko are 1:22.5 when the prototype is a meter-gauge/narrow gauge item, and sorta 1:26 or 1:29 for standard gauge items, like the LGB USA F units or the LGB Mikado. While the Piko BR50 looks great, it will probably not be a scale model (1:32nd for a standard gauge engine) but will be upsized to match the LGB locos.
Take a close look at this excellent scale-gauge comparison by Scott Lawrence and you will see what I mean.
__________________
Pete Thornton is online now   Reply With Quote Quick reply to this message
Old 02-10-2020, 02:20 PM   #4 (permalink)
Junior Member
Default
So what your saying is the MTH 1:32 standard is about the same size as the LGB 1:22.5 Narrow? That's what it looks like on that pic too.
I guess if that's true then I would love to get the MTH Big Boy and use LGB cars. Are the hook ups even compatible?
Old 02-10-2020, 02:39 PM   #5 (permalink)
Senior Member
Default
Hi! I own 2 Piko locomotives. A 0-6-0 Santa Fe switcher, and a 0-6-0 Camelback. They are both of good quality,have full sound,DCC,and smoke. They compare well with LGB,although I think that the Piko's could use a little more detail in certain areas.
Here's a video of my Piko Camelback running with my Bachmann On30 4-6-0 that I made yesterday:
And here's a video of my Piko Santa Fe #728 switcher:
And here's a video of the Camelback being tested on my desktop:
Piko sound systems are made by Soundtraxx. The sound is excellent. They work on either DCC,or analog. They need a power supply of at least 3 amps to operate properly.
I bought a Bridgewerks Mini Mag 3-s,3 amp power supply,as the 1 amp transformer that I was using didn't have enough amp output to power the sound system,and smoke units properly. The flashing headlight in the video showing the Santa Fe switcher was caused by this problem.
Overall, I would recommend Piko products, as they are of very good quality,and not as expensive as a new LGB Mogul with a similar sound system would cost. Their rolling stock,and trackage,while expensive, is beautiful, and I highly recommend them.
Another thing is that Piko,unlike LGB,has a service center located right here in the U.S.
It is in San Diego,Ca,and their tech people are available to answer your questions via email,or you can call,and talk directly, to them.Dan and Jonathan are really great,and I have had the pleasure of talking to them several times.
LGB does not offer this level of service.
All Piko products carry a 1 year warranty.
RkyGriz is offline   Reply With Quote Quick reply to this message
Old 02-11-2020, 07:41 AM   #6 (permalink)
Senior Member
Default
Marklin/LGB does support LGB products here in the US.
Old 02-11-2020, 11:50 AM   #7 (permalink)
Senior Member
Default
Actually 1:29 is visually closer to 1:22.5 models. I believe that was the reason that scale came into existence was to more or less have American standard gauge models that would match visually LGB. While LGB has always used a bit of rubber ruler for things, the American standard gauge cars are near 1:29. I know the Amtrak Genesis was fairly close to 1:29 (some odd dimensions in spots but given LGB flex pretty close).
Lorna is offline   Reply With Quote Quick reply to this message
Old 02-11-2020, 05:11 PM   #8 (permalink)
Junior Member
Default
So I emailed Piko about BR50 scale and how it would look with LGB cars. This is what they replied with.
"The new PIKO BR50 locos are models of standard-gauge prototypes. Much as LGB has done with its models of standard gauge trains, this is not a 1:22.5 scale model. That would require a wider track gauge. So it is a compromise scale of around 1:26 or 1:27, just as LGB did. This fits with the overall size of other LGB and PIKO European style locos and cars."
So that is basically saying a 1:26/27 Standard guage is similar to the 1:22.5 narrow if I'm reading this right.
Old 02-11-2020, 05:28 PM   #9 (permalink)
Senior Member
Default
Well no; actually that depends what you mean by "similar".
A standard gauge locomotive (prototype) tends to be larger than a narrow gauge loco. So a std gauge loco in 1/26th may be visually similar in size to a 1:22.5 but that doesn't make it look correct.
Here's a narrow gauge boxcar next to a standard gauge boxcar:
Now, if you made the narrow gauge (NG) boxcar in 1:22.5 scale, and the std gauge (SG) boxcar in 1:29th, then they would like similar in size.
To further add to your headache, note that NG boxcars were generally smaller, so scaling them up to make them bigger would make them almost the same size as a SG boxcar in 1:29.
This doesn't work for coaches - SG cars are generally much longer than NG cars, so scaling the NG coach up to 1:22.5 to make it match a 1:29 coach looks weird (imho.)
It basically depends on your level of tolerance for non-prototypical trains. Would a BR50 be seen pulling a bunch of USA boxcars - No. But it's your railroad, so you run what you want!
__________________
Old 02-11-2020, 05:46 PM   #10 (permalink)
Junior Member
Default
This is making me lose my mind lol. I think I will just use the LGB Mikado to avoid the pain. It's a beautiful loco anyway. Why must there be so much variety within g scale!
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
