-   -   Eggliner Motor Block Wiring (https://forums.mylargescale.com/29-beginner-s-forum/90656-eggliner-motor-block-wiring.html)
ErieRRFan 07-09-2020 11:55 AM
Got an Eggliner Motor block with four wires coming out of the block and going into one connector. Can someone tell me where to find a wiring diagram or what the four wire are connected to?
thanks
Pete Thornton 07-09-2020 01:20 PM
Quote:
thanks
Well, I'm pretty sure that 2 are track pickups and 2 are to the motor. The parts diagrams for the Eggliner and the FA1 from Aristo are here and confirm it.
https://www.gscale.net/resources/manuals/aristocraft
There's a photo on the Bachmann Parts site of the mtoor block, with yellow, blue, black and green wires.
https://estore.bachmanntrains.com/in...ducts_id=10645
Aristo used 2 connectors - you say there's only one?
I don't recall which wire is which - I'm sure someone knows. In the meantime, a simple multimeter will tell you which are the track pickups - just set the meter to Ohms, and touch one wheel, then use the other lead to find which wire is connected to that wheel. Do the same with the other side and DaDa! The other 2 must be for the motor.
ErieRRFan 07-09-2020 03:25 PM
Just got it from Reindeer Pass. Brown, Blue, Yellow and Turquoise in one connector. Haven't figured out how to attach a photo or else I've forgotten. Will try a multimeter.
thanks
Pete Thornton 07-10-2020 12:18 PM
Here's the pic on the Bachmann website.
So which color is the motor?
https://estore.bachmanntrains.com/im...ge/96275-1.JPG
Greg Elmassian 07-12-2020 04:39 AM
ohmmeter
ErieRRFan 07-25-2020 03:04 PM
Brown and Yellow are the wheels, Blue and Turquoise are for the motor.
krs 07-25-2020 11:56 PM
@ErieRRFan -
For anyone who wants to use that motor block to build their own unit....
Could you measure the spacing between the wheels, ie axle to axle, and also the diameter of the wheels?
Pete Thornton 07-26-2020 12:15 PM
Quote:
Originally Posted by krs (Post 1157802)
@ErieRRFan -
I believe it is the same as the Aristo FA motor block. Bachmann says on the parts listing "Compatable with Aristo engines". I'm sure the Aristo experts can tell you other uses for that truck.
Greg Elmassian 07-26-2020 12:26 PM
It is the same, has been used to replace Aristo blocks in many cases.
All 2 axle Aristo diesels use the same diameter wheel.
krs 07-26-2020 01:00 PM
So does it tell you somewhere what the dimensions are?
For people who don't have any Aristo locos....
