Eggliner Motor Block Wiring - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 07-09-2020, 11:55 AM   #1 (permalink)
Junior Member
Default Eggliner Motor Block Wiring
Got an Eggliner Motor block with four wires coming out of the block and going into one connector. Can someone tell me where to find a wiring diagram or what the four wire are connected to?
thanks
ErieRRFan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-09-2020, 01:20 PM   #2 (permalink)
Senior Member
Pete Thornton's Avatar
Default
Quote:
thanks
Well, I'm pretty sure that 2 are track pickups and 2 are to the motor. The parts diagrams for the Eggliner and the FA1 from Aristo are here and confirm it.
https://www.gscale.net/resources/manuals/aristocraft
There's a photo on the Bachmann Parts site of the mtoor block, with yellow, blue, black and green wires.
https://estore.bachmanntrains.com/in...ducts_id=10645
Aristo used 2 connectors - you say there's only one?
I don't recall which wire is which - I'm sure someone knows. In the meantime, a simple multimeter will tell you which are the track pickups - just set the meter to Ohms, and touch one wheel, then use the other lead to find which wire is connected to that wheel. Do the same with the other side and DaDa! The other 2 must be for the motor.
__________________
Pete Thornton is offline   Reply With Quote Quick reply to this message
Old 07-09-2020, 03:25 PM   #3 (permalink)
Junior Member
Default
Just got it from Reindeer Pass. Brown, Blue, Yellow and Turquoise in one connector. Haven't figured out how to attach a photo or else I've forgotten. Will try a multimeter.
thanks
Old 07-10-2020, 12:18 PM   #4 (permalink)
Senior Member
Default
Here's the pic on the Bachmann website.
So which color is the motor?
__________________
Old 07-12-2020, 04:39 AM   #5 (permalink)
Greg Elmassian's Avatar
Default
ohmmeter
__________________
Old 07-25-2020, 03:04 PM   #6 (permalink)
Junior Member
Default
Brown and Yellow are the wheels, Blue and Turquoise are for the motor.
Old 07-25-2020, 11:56 PM   #7 (permalink)
krs
Senior Member
Default
@ErieRRFan -
For anyone who wants to use that motor block to build their own unit....
Could you measure the spacing between the wheels, ie axle to axle, and also the diameter of the wheels?
krs is online now   Reply With Quote Quick reply to this message
Old 07-26-2020, 12:15 PM   #8 (permalink)
Senior Member
Default
Quote:
Originally Posted by krs View Post
@ErieRRFan -
I believe it is the same as the Aristo FA motor block. Bachmann says on the parts listing "Compatable with Aristo engines". I'm sure the Aristo experts can tell you other uses for that truck.
__________________
Old 07-26-2020, 12:26 PM   #9 (permalink)
Default
It is the same, has been used to replace Aristo blocks in many cases.
All 2 axle Aristo diesels use the same diameter wheel.
__________________
Old 07-26-2020, 01:00 PM   #10 (permalink)
krs
Senior Member
Default
So does it tell you somewhere what the dimensions are?
For people who don't have any Aristo locos....
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
