LGB 2017 Stainz motor - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 07-14-2020, 03:19 PM   #1 (permalink)
Member
Default LGB 2017 Stainz motor
Found my problem with the Stainz. Motor is toast. Turns a bit stiffly, does not respond with power applied directly to the two copper tangs that go to the brushes..Before I try to source an OEM motor, is there a suggested upgrade motor for the task?
gizmorama is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-14-2020, 10:20 PM   #2 (permalink)
Senior Member
Michael Glavin's Avatar
Default
No upgrades I'm aware of...
Forum sponsors offer OEM replacements:
Train Li USA
Reindeer Pass
Michael
Michael Glavin is offline   Reply With Quote Quick reply to this message
Old 07-15-2020, 07:38 AM   #3 (permalink)
Senior Member
Default
Which motor was in your stainz? there are 3 different versions (not including Growler) of the LGB short shaft motor, and only one version is now available which has no easily removable brushes. Both older stainz motors had the red and black modules. difference in these was one had no thrust bearings and the motor block has a single ball bearing at the end of the shafts. Other had thrust bearings and the bearings were not needed.
Old 07-15-2020, 01:56 PM   #4 (permalink)
Member
Default LGB 2017 Stainz Motor
Early one based on the ball bearing . . thanks
And those brushed WOULD be a bear to deal with.
Old 07-16-2020, 06:25 AM   #5 (permalink)
Senior Member
Default
Remove the bearings when installing the new sealed motor.
Old 07-17-2020, 05:43 PM   #6 (permalink)
Member
Got it: no bearing with new motor.
Reply
Tags
0-4-0, lgb, motor upgrade
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
