Mean Well power supply - Page 2 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 10-22-2011, 07:15 PM   #11 (permalink)
Senior Member
Polaris1's Avatar
Default RE: Mean Well power supply
Per Greg E....... I bought the Meanwell 11 Amp 27 Volt unit at JameCo for the $70 price..... + shipping.
I had trouble snapping off the terminal plastic cover needed to protect the hot 110v contacts....
Plastic cover removes easily if you roll it from the top down...... Snaps on super quick.
I plan to use the Meanwell with the RC (radio Control) mode setup with the Bridgewerks UR-15 DC track feed.
Doing garden bulb/tuber work over the past 5 days & trains are both parked & blocked... in GBay, WI... (5-0 Country..)
Polaris1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-22-2011, 07:22 PM   #12 (permalink)
Senior Member
kormsen's Avatar
or you build your own powerpack.
http://www.wikihow.com/Image:ATX-to-Lab-PSU-6.JPG
add a rheostat and you are ready to run.
i just did that, and i am content with two new 24 Volt 15 Amp DC powerpacks.
__________________
Southern & Gulf R.R.
We build for eternity! (so, why should we hasten?)
kormsen is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 07:39 PM   #13 (permalink)
krs
Senior Member
Gregg -
The "preferred" Meanwell supply depends a bit on the application, ie the voltage you want for the device that you're powering.
The one linked to above has a nominal 27 volt output which is adjustable from 26 to 32 volts and it provides an output current of up to 11 amps.
I tend to go for the 24 volt version where the output is adjustable from 20 to 26.4 volts and you get a bit more current - 12.5 amps.
All depends what you are driving with that supply.
I also tend to go for the PFC version of the Meanwell which is a bit more money but it saves a bit of money in the long run. Not sure it makes total financial sense from a payback perspective since we don't run our trains for long periods every day but it's definitely more environmentally frindly.
krs is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 08:08 PM   #14 (permalink)
Greg Elmassian's Avatar
The reason I have recommended the 27 volt one is for DCC where 27 volts input normally yields 24 volts to the rails, helpful in many DCC situations.
Also, the NCE system I use is a 10 amp system, so over 10 amps is basically wasted.
__________________
Old 10-22-2011, 10:28 PM   #15 (permalink)
krs
Senior Member
Posted By Greg Elmassian on 22 Oct 2011 08:08 PM
Yes - for your application (powering the NCE DCC system) the 27 volt version makes sense and is the correct one to chose.
I used my first Meanwells with a home-brew analogue throttle which had a fairly low voltage drop at maximum and for that application even the 24 volt unit provided more voltage than what I needed.
But since I'm going to use that supply in the future, I decided not to go with a lower voltage which I could have done for that initial analogue use.
Knut
Old 12-08-2019, 10:24 AM   #16 (permalink)
Junior Member
Default
Is it safe to use a Mean Well power supply with an LGB throttle, such as the 51070, 51079, 52120 or 52121? Reason I ask is that I have read that using an LGB throttle with a non-LGB power supply may cause the short circuit protection to fail.
Also, with a Mean Well power supply and an LGB throttle, would you get pure DC or pulse power?
alx19881 is offline   Reply With Quote Quick reply to this message
Old 12-08-2019, 02:13 PM   #17 (permalink)
Default
Dude, you really need to make a new thread instead of jumping on an 8 year old one.
Next, you do not post the same question in several places, one place is enough.
I answered you on the slightly newer thread.
__________________
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
power supply? Wally's Express DCC in Large Scale 1 09-18-2013 12:10 AM
Help with power supply bcer960 DCC in Large Scale 24 03-25-2011 09:32 AM
New Power Supply NavyTech Traditional Power 10 06-03-2010 05:45 PM
POWER SUPPLY danielr49 Traditional Power 1 02-21-2010 10:22 PM
Power Supply for NCE Power Pro 10-R vg3616084 DCC in Large Scale 13 01-31-2010 10:08 PM
