Mean Well power supply - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 07-24-2011, 10:59 PM   #1 (permalink)
Senior Member
dieseldude's Avatar
Default Mean Well power supply
Well, its time to add some dedicated power to my other loops. Up 'til now, I've been running everything with a single Aristocraft Ultima 10 amp power supply. But, with the constant addition (or addiction!) of more engines, more rolling stock, and thus longer trains- it's time to invest in more power. I've heard about people using the Mean Well power supplies with some success. TRC Electronics has some pretty good prices on them. Since, I already own a couple of extra Aristocraft CRE-55460 10 amp controllers, I figured the Mean Well supplies might work out good. Naturally, I've got some questions (and I know you have answers!!!). Here goes.......
1- Is anyone using the Mean Well with the Aristocraft 10 amp controller? Hows it working out- any issues?
2- I'm guessing that I'd want to buy the 10 Amp, 24 Volt Mean Well (TRC Electronics #SP-240-24). I'll probably buy 2 of them- One for each separate loop of track. Then, I'd have more than enough power on each loop to run whatever I want (double headed freight trains, long heavyweight passenger trains, etc).
3- Does anyone sell the mate to the modular plug that is already on the Aristocraft controller? I know its not necessary, but it I don't want to cut it off the controller and hardwire it to the power supply. I'd rather make a pigtail on the power supply and be able to just plug in the controller- just like on the Ultima (I know, I know, call me picky........).
4- IF...... some day I decided to buy an Aristocraft Train Engineer (probably the old system CRE-55470), would I run into any compatibility issues?
5- Any other thoughts, ideas, recommendations, etc. are always welcomed.
As always- Thanks for the help.
-Kevin.
dieseldude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-25-2011, 06:02 AM   #2 (permalink)
Senior Member
Default RE: Mean Well power supply
I have 2 friends that use the Aristto 13 amp 22.5 volt supply with the 27mhz trackside train engineer. They have had no problems.
Just one thing to remember, the train engineer receiver must be 3 feet from a power source for consistant programming. Really 3 feet from any electronics such as power supplies or even telephone/blu-ray equipment.
I use a 8 amp 24 volt supply outdoors in New England with my trackside 27mhz TE and it has been in use for 8 years with no issues.
I do run a small loop with the Ultima and this powers my accessroy receivers as they have a 22 volt DC limit.
I also support a club that uses 2 potran 6.5 amp 24 volt power supplies with 2 trackside TE's with no problems to date.
So, I do not have a mean well, but do use other supplies with 24 volt regulated supply ratings.
Old 07-25-2011, 08:44 AM   #3 (permalink)
Greg Elmassian's Avatar
I use the meanwell, (have several) and have recommended it as a reliable, low cost regulated switching supply.
Many of my friends have bought them.
Recommended.
p.s. you have to add your own power cord and power switch.
__________________
Old 07-26-2011, 07:57 AM   #4 (permalink)
Senior Member
Del Tapparo's Avatar
I use to use a Meanwell when I ran track power with a A/C trackside train engineer. It worked great.
__________________
Del Tapparo
Custom Vinyl Lettering & Simple Low Cost Battery Power
www.GScaleGraphics.net
Del Tapparo is offline   Reply With Quote Quick reply to this message
Old 07-27-2011, 02:44 PM   #5 (permalink)
Junior Member
I use a Mean Well 15A/24V supply split between two controllers. Have happily powered trains with for the past couple of years.
The only problem I have experienced is with a DCC locomotive that is supposed to be able to run on DC. According to the locomotive manufacturer, at what appears to be 9V on the track to a normal locomotive, has pulses in the power to which exceed 21V, and the DCC card shuts down. Whether that is true, or they are just pointing at that so not to fix there locomotive. I don't know.
Hope this helps.
jaanth is offline   Reply With Quote Quick reply to this message
Old 07-27-2011, 03:39 PM   #6 (permalink)
Many large scale decoders are derived from HO decoders, and do not have the proper voltage handling for LS, which is a max of 27 volts DC. (22 volts DCC)
So Tsunami (found in Bachmann), some Digitrax, and some other brands are not tolerant.
If you go to the DCC standards, you will find the max DC voltage should be 27 volts on decoders over "N" scale. look in section "C", line 71 states this..
Here's the document:
http://www.nmra.org/standards/DCC/s...004-07.pdf
They may still tell you to shove it, but they cannot tell you that it meets the NMRA DCC standard.
__________________
Old 07-27-2011, 05:17 PM   #7 (permalink)
krs
Senior Member
Posted By jaanth on 27 Jul 2011 02:44 PM
Well, the DCC card is not supposed to shut down at 21 volts as Greg pointed out, but just for interest - how did the loco manufacturer decide that there were21 volt pulses in the output of the Meanwell (or am I misinterpreting what you wrote?).
First Meanwell supply I bought to run my trains was a 24 volt 6.5 amp unit - I measured it's output characteristics and every parameter including noise was well within specs.
There were no 21 volt spikes or any other spikes of any magnitude.
I later found a very detailed test report of those types of Meanwell power supplies on line - done by an independant lab - they tested every last specified parameter (which I hadn't done) and evry last one was well within the published specs. I was quite impressed with the quality of those supplies compared to the price they are sold for.
Knut
krs is offline   Reply With Quote Quick reply to this message
Old 07-27-2011, 11:02 PM   #8 (permalink)
Funny, the manufacturer is already trying to blame something else, and they have their facts wrong on the max DC voltage... unless they specify that they are not NMRA compliant, and cannot correctly call their decoder DCC...
They are probably thinking that max DC voltage is the same as max DCC voltage...
Just baloney...
After all this, what is the manufacturer and model of the decoder?
__________________
Old 10-20-2011, 12:53 AM   #9 (permalink)
Member
Could someone add a link to the Mean Well power unit and/or which one is the preferred one for model trains 10-15 AMPs.
Thanks
gregg k is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 06:42 PM   #10 (permalink)
Senior Member
aceinspp's Avatar
Gregg try here. http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&pa=693581&productI d=693581&keyCode=PDF Later RJD
__________________
Home of the Dakota & Southern RR
SA 2510
aceinspp is offline   Reply With Quote Quick reply to this message
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
power supply? Wally's Express DCC in Large Scale 1 09-18-2013 12:10 AM
Help with power supply bcer960 DCC in Large Scale 24 03-25-2011 09:32 AM
New Power Supply NavyTech Traditional Power 10 06-03-2010 05:45 PM
POWER SUPPLY danielr49 Traditional Power 1 02-21-2010 10:22 PM
Power Supply for NCE Power Pro 10-R vg3616084 DCC in Large Scale 13 01-31-2010 10:08 PM
