LGB-2-6-0 motor problem - Page 2 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 03-28-2017, 11:36 AM   #11 (permalink)
Greg Elmassian's Avatar
Default
It's got to be in the electronics, since you have proved the 4 connections to the motor block work.
In the "4 wire" motor block, the track pickups and the motor pickups are all isolated from each other. So since the motor runs, both motor wires in the block are fine. Since the loco moves on the rails, both track pickups are fine.
So somewhere there is a diode between one of the track pickups and the motor. I was under the impression that the motor on/off switch was a single pole single throw, or a single pole double throw, so it should only be interrupting one "side" of the motor connection.
Something is really strange. You can try applying power to the motor plug (wires from the motor block), but I'm pretty sure that part is ok.
__________________
Sponsored Links
Advertisement
Old 03-28-2017, 11:48 AM   #12 (permalink)
Member
Default
Greg,
I tend to agree with you. I hate being a "parts changer" type of mechanic and like to accurately diagnose the problem before buying parts. What you suggested about the electronics was my gut feeling but I wasn't sure.
Bill
rntfrmme is offline   Reply With Quote Quick reply to this message
Old 03-28-2017, 11:27 PM   #13 (permalink)
Default
Does the motor control switch actually enable/disable the motor powered from the track (test in the direction it runs of course)
That might give a clue.
__________________
Old 03-29-2017, 10:51 AM   #14 (permalink)
Member
Default
Greg,
I will try that and see what happens.
Bill
Old 03-30-2017, 09:13 AM   #15 (permalink)
Senior Member
Default
26194 is a digital with digital sound in the engine, wires going to the tender are:
2 for track power
2 for rear light
2 for speaker.
It could be the MTS board needs a reset, cv 55 to 55.
If you are analog only, this reset can not be done.
Also if you have pulsed power of any kind the decoder may act strange.
Old 03-30-2017, 10:41 AM   #16 (permalink)
Member
Default
Dan,
Its always good to learn. Mine has the six wire plug as described. Now I need to figure out how to reset the board. I'm analog only. ugh!
Old 03-31-2017, 08:12 AM   #17 (permalink)
Senior Member
Default
Join a club in Vegas and someone there should have a DCC system and can do the reset.
Or, if you know how to take the engine apart, you can send the board (actually the metal plate with both boards, bottom board is sound, top is DCC.to me to check it out.
I have fixtures to test out the LGB onboard decoders like the one in your engine.
Old 03-31-2017, 11:30 AM   #18 (permalink)
Member
Default
I do belong to the club here in Vegas. I need to find a member who can test it. Hmmmmmm.
Old 04-01-2017, 07:19 AM   #19 (permalink)
Senior Member
Default
On another note, the DCC decoders can turn off analog operation with CV 29. The reset will turn analog operation back on. Again, setting CV 55 to 55 will reset the original LGB mogul decoder for analog operation.
Old 04-01-2017, 12:39 PM   #20 (permalink)
Default
Still, no DCC setting can explain running in one direction and not the other.
__________________
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LGB MOTOR 1toppump Beginner's Forum 10 01-12-2020 11:17 PM
LGB Mallet motor riderdan Rolling Stock 7 07-28-2014 05:45 AM
Need LGB parts (motor especially) scoobster28 Model Making 4 11-29-2011 09:42 AM
One motor on Dual Motor LGB trains siezing up bcwa Public Forum 11 02-14-2009 09:13 AM
Help with DC motor problem? lownote Rolling Stock 10 07-10-2008 06:33 PM
