Issue with MRC Power G - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 03-12-2019, 12:47 PM   #1 (permalink)
Junior Member
Default Issue with MRC Power G
Hi all -
Last year, I bought an MRC Power G transformer, which I have been using to run my LGB F7, as well as my two USA Trains F3 engines. Recently, I have noticed that when I am running any one of my engines slowly, the engine will make a humming/buzzing sound. As I run the engine faster, the sound will cease. And if I use my other transformer, a USA Trains Power 10, I do not get this sound. Does anyone have any idea as to why my MRC Power G is doing this?
alx19881 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-12-2019, 05:33 PM   #2 (permalink)
Member
Default
Maybe because it doesn't know the words........I'm sorry I couldn't resist. I'm no electronics guy so no help from me....:-(
rntfrmme is offline   Reply With Quote Quick reply to this message
Old 03-12-2019, 08:21 PM   #3 (permalink)
Senior Member
Totalwrecker's Avatar
Default
Give 'em a call ...(732) 225-6360
__________________
Happy Rails,
John
His friend Jerry Dillon looked up at the hillside and said; There is a big ledge, and the whole damned hill is a total wreck with quartz boulders of ore.
Totalwrecker is offline   Reply With Quote Quick reply to this message
Old 03-13-2019, 07:32 AM   #4 (permalink)
Senior Member
Default
I would suspect a pulsed power output is the culprit. Install a linear device on the output like they use on the revolution to make pulsed powewr look to be linear by soothing out the pulses with capacitors.
Decoders especially do not like pulsed power as they see a pulse but can not sync to it as it is not a dcc signal.
And then there is Marklin decoders which look for in this order.. Marklin digital, DCC, and lastly DC power. If you have a digital system, you can turn off marklin but it will still look for DCC before it goes to DC.
Dan Pierce is online now   Reply With Quote Quick reply to this message
Old 03-14-2019, 07:46 PM   #5 (permalink)
Senior Member
Default
I know that most MRC transformers are not pure Dc and have a pulse in them
choochoowilly is offline   Reply With Quote Quick reply to this message
Old 05-30-2019, 07:34 PM   #6 (permalink)
Junior Member
Default
Actually the Power G is not pulsed, but it is not filtered very well, so it has a lot of 60Hz in the output.
I looked at an MRC power G, with the output set to 12V and a moderate load (1A) - the output varied by 6.8V peak to peak. By comparison, a Bridgewerks 5A supply (Magnum 5 SR) at 12 V and 1A out has less than 0.1V of variation.
Mark_s is offline   Reply With Quote Quick reply to this message
Old 05-31-2019, 07:10 AM   #7 (permalink)
Senior Member
Default
6.8 volts of peak to peak sounds like a pulse to me and would cause a motor to hum.
Old 08-01-2019, 01:43 PM   #8 (permalink)
Junior Member
Default
I'm a couple of months late here, but: The thing to do with your MRC power device would be to check the output with an oscilloscope. If there are pulses, they will show up on the screen. I don't know much about the MRC. If you had a schematic, you could determine whether there was enough filter capacitance to get to the level of pure DC.
Several years ago, I built a dual (A and B Cab) power supply for my model railroad which has about 165 feet of track around the second floor wall of my barn-workshop. I used my oscilloscope to examine the output of the units and found that I did not have enough capacitance to fully clean the output. After some trial and error, I settled on a compact capacitor of 6,800 micro farads on each side and now the outputs are very nice and clean.
Zigeuner is offline   Reply With Quote Quick reply to this message
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
MRC Power G vs Bridgewerks 5SR 5 amp tcaron20 Traditional Power 11 01-09-2013 07:57 PM
MRC AG990 Power G 10 Amp intermittent power problem lincoln pin Traditional Power 4 05-02-2010 10:54 PM
MRC Power G- Buttons? OGC5 Traditional Power 2 09-02-2009 04:35 PM
MRC AD322 Decoders and MRC AD501 Boosters Jerry McColgan DCC in Large Scale 1 12-14-2008 11:27 AM
MRC Power G? Ted Yarbrough Traditional Power 7 07-13-2008 03:52 PM
