-   Traditional Power (https://forums.mylargescale.com/38-traditional-power/)
-   -   Stainz troubleshooting (https://forums.mylargescale.com/38-traditional-power/90676-stainz-troubleshooting.html)
gizmorama 07-14-2020 11:08 AM
I just bought a well worn Stainz 0-4-0 and went to test it. Using a Bachman 3amp variable power supply, the voltage goes up, the amps stay at zero.
I even hooked up the power by a set of test leads to the skates. No joy.
I've used this power supply on LGB locos in the past and there was no problem.
If I remember my basic electricity, zero amps means that the motor is not getting connected to the power.
So, before I tear down the loco, are there any tips and tricks.
And any tear down advice? I should be able to find a parts diagram somewhere on the net.
Thanks in advance
WES
gizmorama 07-14-2020 04:08 PM
After the teardown, found the motor turns stiffly and does not run when power applied direct to the two brass power pickups (that go direct to brushes) - now looking for an upgrade motor or replacement.
Dan Pierce 07-15-2020 07:41 AM
LGB 62201 short shaft motor. Trainli.com, just under $60 plus shipping.
gizmorama 07-16-2020 03:03 PM
Never leaving well enough alone, I kept digging.
Finally found the culprit: the brush spring on the 'red' side has no tension, so the brush does not touch the commutator.
