Battery-RC- Sound cost - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 04-01-2008, 09:10 PM   #1 (permalink)
Default Battery-RC- Sound cost
How much does it cost to convert to a battery operated RC system with sound?
Air wire 900- RCS- does not matter- Phoenix sound. 21.6 volt Li-on or Nmh batteries.
And where do your have them done?
Thnaks in advance.
woodone is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-02-2008, 04:43 AM   #2 (permalink)
Senior Member
lvmosher's Avatar
Default RE: Battery-RC- Sound cost
Depends on a number of things but assuming you don't have a battery charger (Triton) or 12vdc power supply for it and you pay some one to do it it could go to $1100 -$1200 Do it yourself and take off $350. Have a battery charger and power supply take off $225.
__________________
Larry
lvmosher is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 06:31 AM   #3 (permalink)
Senior Member
Most battery/RC users will have a hand held throttle from their favourite system and a battery charger for their favourite battery type. These of course will have to be acquired initially and these sunk costs are the primary reason why folks don't like to change systems once they have one installed even though in a sense each loco is self contained. Personally I use both RCS and Aristo RC systems of varying types depending on the application.
Now for costs. Aristo is the least expensive. For high amp draw situations, I like the 27 MHz trackside board removed from its case and installed in a loco. This receiver/motor controller costs about $120 from a discounter (I get mine in Canada from Art Knapp). The installation will involve some switches, jacks and noise suppression so figure another $10-15 for components. If sound is required an accesory board will be needed (cost $70 approx) though I would recommend using a higher end system if you wish to install sound. The Aristo 75 MHz mobile has had range problems due to poor aerial choices and inadequate motor noise suppression - our club members have a wide experience with them and have finally gotten reliable operation from them. See www.ovgrs.org for lots of battery RC details.
The RCS system has a number of ergonomic and functional advances over the Aristo and would be my choice if sound were to be used. Cost of an RCS Elite system of appropriate amperage runs to about the same price as an Aristo system including the accesory board.
Sound is easily installed with RCS and controlled with RCS - the cost of Sierra runs to a bit under $200 and of Phoenix just over $200 - I have never used other sound systems.
Installation of all this stuff can be done commercially and Larry's $300 plus is certainly a figure which you could work with. I have had some custom installs done by Dave Goodson and I have done some of my own (guess which ones are better!)
Battery packs can vary in price depending on whether you wish to use NiMH or Li ion, whether you have a custom pack built od roll your own, the number of cells you wish to use, and on whether you use Double As or sub Cs. For the typical B'mann steam loco, I would use 14.4V or 12 cells double As NiMH. I have an Aristo diesel powered by 19.2V of sub Cs NiMH and am in the process of building a heavy duty power car containing a pair of Aristo Li ion packs. I suspect that you can obtain battery packs from a discount supplier for well under $50 for NiMH while the Li ion may be a bit more. Make sure you have appropriate charging technology as the use of the wrong charger (especially with Li ion) can cause fires.
I have no experience with other systems though there are folks who swear by their Airwire RC.
I would also suggest that you take a look at the newly announced but not yet fully available GWire system that uses QSI sound - this may give a lower overall price for a fully configured system. Keep in mind that it is not yet available widely and that it may have some teething problems.
Similarly, Aristo has announced a new RC system coming soon as a replacement for their 75MHz mobile but it is also not yet available. Typical of Aristo products, I would expect it to be a low price leader but I would also expect a few idiosynchrosies along the way.
Regards ... Doug
__________________
[b]Doug Matheson
Manotick Ontario
SA #122
Dougald is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 07:33 AM   #4 (permalink)
Senior Member
Torby's Avatar
Send a message via Yahoo to Torby
I put an Aristo Trackside TE in my Annie:
1. TE transmitter and receiver: $130 (I found where I can get them for $110.)
2. Small Scale Railways sound card with 1w amp: $90
C. 2 Battery holders from junk box. Free (about $7 at Radio Shack)
4. 12 AA "Coppertop" batteries from Wal*Mart: $7.50 (Coppertops seem to last the longest)
That comes to $235 or so. I started out without the sound card and added it later.
__________________
Electronic junk you never knew you needed:
http://www.barefootelectronics.com
Torby is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 09:04 AM   #5 (permalink)
Senior Member
Del Tapparo's Avatar
14.4V NiMh battery pack, 2200mah ... $30
Basic Critter Control (Manual speed controller, not R/C) ... $74
Misc (Power on/off switch, charging jack, wire, etc.) $10
Cost per loco ... $124
E-Flite Pinnacle Plus charger ... $100
Not bad [img]/DesktopModules/NTForums/themes/mls/emoticons/satisfied.gif[/img]" border=0>
Edit: and do it yourself. Really pretty simple. All of the various systems come with well written installation instructions.
__________________
Del Tapparo
Custom Vinyl Lettering & Simple Low Cost Battery Power
www.GScaleGraphics.net
Del Tapparo is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 08:57 PM   #6 (permalink)
Thanks for all of the replys.
Looks like there are many different ways to go about this task. Different costs too.
And then you must pack it up and ship it to whom you will have do the install, and I am sure the cost of shipping back and forth will get pricey.
Old 04-03-2008, 08:50 AM   #7 (permalink)
Dougald,
I have installed an RCS system. having range problems. I could not find the link that you provided in your reply to me.
Can you give me some help on getting that information?
Thanks, woodone
Old 04-03-2008, 09:00 AM   #8 (permalink)
Senior Member
Jerry Barnes's Avatar
Some of mine are just set up with a simple DPDT switch, just throw it and let it run till the batteries run down. I also have some with R/C, one with the Aristo, which I like and one with RCS which I also like fine. Jerry
Jerry Barnes is offline   Reply With Quote Quick reply to this message
Old 04-03-2008, 09:46 AM   #9 (permalink)
Guest
Posts: n/a
Posted By woodone on 04/03/2008 8:50 AM
Dougald,
I have installed an RCS system. having range problems. ....
Thanks, woodone
425-823-3507 Dave Goodson-Call Him!
Answer to post question:
If I remember right....When I did my Annie Install with Sierra Sound and RCS Elite Throttle, with TX 24 remote...it ran somewhere near $500+/-...that includes 14.4v NiCads, plugs, wires, etc (everything) except labor to install (I wanted to and did that part)...
With RCS depending on what you are putting it in and what you want it to do...you at least need:
Batteries
Throttle/Receiver
Transmitter
to answer your question completely, I'd recommend the same advice above..>Call Dave-tell him what you are looking to do and let him help you decide what you need and then figure cost...He is a dealer, and it's really that easy! He has always been very Gracious in his helps given to me!
Old 04-03-2008, 09:08 PM   #10 (permalink)
I have talked to Dave and he was most helpful. On the range problem he sugested using a wheel wiper to use the rail on one side to act as an antenna. I have done that but still not happy with the range. As long as you are close to the rail it works farily well, move away and you loose control of the locomotive.
Any one know the correct length the antenna should be for 27mh.
Thanks for all the input,
This has been a learning experience for me. An I am still learning thanks to all of the good ideas that show up here on the boards.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Battery/DCC Cost Question calaski8123 Beginner's Forum 60 10-05-2013 04:34 PM
Phoenix sound battery Trains Sound Systems 13 11-25-2012 07:57 AM
Battery for Sierra sound Doug Bowman Sound Systems 1 03-01-2010 04:33 PM
Installing RC/sound/battery in F3-AB. pimanjc RC/Battery Operations 10 03-02-2009 09:12 PM
Battery and sound forum????? todd55whit Public Forum 1 01-02-2008 07:35 PM
