Lifetime of Tenergy ion-lithium battery - Page 2 - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 04-06-2020, 09:54 PM   #11 (permalink)
Senior Member
Michael Glavin's Avatar
Default
Dwight is correct, the life cycle of Lithium cells starts once the chemical matrix is combined. Batteries could be assembled years after the cells were first manufactured. Purchasing your batteries from a reputable battery assembler utilizing quality fresh inventory is paramount to happy life cycles.
FWIW: Some of the information of the Mechanics Illustrated article linked above is dated (2012) and or inaccurate IMO. As I often allude to there is a lot of misinformation out there with regard to Lithium batteries. If your interested in this type of information there are many sources with current and or accepted practices and realizations available online. The Battery University is one of many.
https://www.google.com/search?source...=1586224020071
Michael
Michael Glavin is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2020, 09:58 PM   #12 (permalink)
Senior Member
Default
Quote:
Originally Posted by Michael Glavin View Post
mymodeltrain<
If you’ll please provide data specific to your care, feedingand use of the failed Li-Ion batteries, collectively we maybe able to offer whatmay have led to the demise of your batteries.
Voltage: 14.8
Capacity: ?
Charger model number and or specifications: ?
Charging frequency/interval: ? (can you estimate total charge/runcycles)
Typical run time(s): ?
Are your loco’s fitted with the same batteries?
Please call out the loco brand/model?
Please describe your typical operation, i.e., charge andrun trains until train stops, run trains with partially charged battery until theystop, stop train prior to depleting batteries???
Please describe how you care for the batteries after arun?
There is a lot of misinformation out there with regard tothe “proper use” and charging demands of said batteries.
Tenergy like all other battery technology resellers,purchases OEM cells and assembles and or packages them as battery packs for resale.Whose OEM cell is utilized is an unknown unless it called out in Tenergyspecifications. Accordingly, all Tenergy packs are not of like origin, quality,age and more. As an example, one 14.8V battery maybe comprised of Panasoniccells while others maybe use Sanyo, LG Chem or others. The quality and shelf lifeof the cells used to assemble a given run of batteries, together with the careand use of said batteries will dictate its life span.
Michael
Years of usage: ~3 years
Voltage: 14.8 V
Capacity: 2600 mAh
Charger: Tenergy Universal Smart Charger, 1.5 Amp for 14.8 V Lithium-ion batteries
Frequency of running time: 2 hours in the weekend during Fall/Winter; Spring: 4-6 h/week-end. So most of the time the locomotives just sit inside the garage. Sometimes, I run until the battery is dead, and would bring them back to the garage to plug the charger in. But most of the time, the locomotives have a half-full battery.
locomotive types: LGB or USA Trains.
mymodeltrain is offline   Reply With Quote Quick reply to this message
Old 04-06-2020, 11:29 PM   #13 (permalink)
Senior Member
Default
Okay, some quick observations:
The charger in play is appropriate for 14.8V, 2600mAh battery.
NEVER run the batteries down until the train stops!!!! Contrary to the miss-information that many abide by, this is detrimental to the batteries life cycle.
What specific loco's? The LGB's are likely fine, yet USAT engines are hungry and will pull more current than the LGB's.
Best practice is to store your batteries partially charged, at STORAGE voltage which is typically 3.8V per cell as I recall.
Charge your batteries often with the appropriate current, do not wait until they are fully discharged, this is the established standard. Minimal discharges are best with a toping charge between use(s).
I recommend reviewing the link I provided above for up to date accurate/proven/knowledge on all things battery.
Michael
Old 04-07-2020, 09:36 AM   #14 (permalink)
Senior Member
Homo Habilis's Avatar
Default
Just to add, all of my receivers are the G Scale Graphics RailBoss 4. One of its features is a low battery warning and cutoff system for Lithium batteries. To my recollection I've only had it activate for one engine so I don't think I've ever fully drained any of my battery packs.
Homo Habilis is offline   Reply With Quote Quick reply to this message
Old 04-07-2020, 10:09 PM   #15 (permalink)
Senior Member
Default
Michael
Thanks, Michael for the experience, I will observe these steps in the future.
Old 04-07-2020, 11:32 PM   #16 (permalink)
Senior Member
Default
I have quit buying the 14.8v Tenergy batteries. I have had several of them fail in what I PERSONALLY think was a short life span. All my new ones are the 6800mah from Airwire. Time will tell.
__________________
Paul Burch
Sierra Cascade & Pacific R.R.
Gig Harbor Washington
Paul Burch is offline   Reply With Quote Quick reply to this message
Old 04-08-2020, 03:42 PM   #17 (permalink)
Greg Elmassian's Avatar
Default
Paul is not the first person to indicate that perhaps the Tenergy packs have changed in "lifespan", I've heard it from a number of our club members too.
I wish that packs came in clear shrink, so you could look inside and see the manufacturer of the batteries.
__________________
Old 04-09-2020, 11:38 AM   #18 (permalink)
Senior Member
Totalwrecker's Avatar
Default
https://www.batteryspace.com/
I have been happy with these folks for a long time. I started with their bike light /rechargeable flashlights for mine explorations, I could recharge in my truck away from home.
Then I used their NiMH tabbed batteries to make custom packs and then the Lithium packs after my others passed on....
__________________
Happy Rails,
John
His friend Jerry Dillon looked up at the hillside and said; There is a big ledge, and the whole damned hill is a total wreck with quartz boulders of ore.
Totalwrecker is offline   Reply With Quote Quick reply to this message
Old 07-03-2020, 07:37 AM   #19 (permalink)
Junior Member
Default
about 2 to 3 years
traukinys is offline   Reply With Quote Quick reply to this message
Old 07-07-2020, 05:13 PM   #20 (permalink)
Super Moderator
East Broad Top's Avatar
Default
"Average" for me is 5 years of reliable service. I've got some that have lasted much longer (10+ years) and others which have for whatever reason stopped working properly after two or three. I try to make the packs removable in my installations whenever practical, which cuts down on the number of batteries I need to buy.
Later,
K
East Broad Top is offline   Reply With Quote Quick reply to this message
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
