Lifetime of Tenergy ion-lithium battery - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 04-06-2020, 02:15 PM   #1 (permalink)
Senior Member
Default Lifetime of Tenergy ion-lithium battery
I would like to hear the experience from others regarding the Tenergy ion-lithium battery. It seems to me after > 3 years, the battery degraded to the point it won't power the train. I use the RC-receiver/transmitter and ESC from Turnigy. What happened in the past few days was that there was normal response sound from the ESC but the locomotive did not run. I opened it up and found everything is normal in terms of the response from the transmitter/receiver and ESC, but again the train did not run. Then, I removed the Tenergy ion-lithium battery (14.8V) from the locomotive and connected the ESC directly to the DC-transformer, and the train started to run normally. Based on this diagnosis, it suggested that the battery degraded. I just ordered new Tenery ion-lithium battery and will assemble it this evening and will update you more.
Wellington
mymodeltrain is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2020, 03:28 PM   #2 (permalink)
Senior Member
Pete Thornton's Avatar
Default
I think I would have ordered one from a different supplier!
__________________
Pete Thornton is offline   Reply With Quote Quick reply to this message
Old 04-06-2020, 04:01 PM   #3 (permalink)
Senior Member
Default
Quote:
PETE,
Do you know any other suppliers, please let me know so I can try in the near future. I just found another locomotive that has the same issue. I will check the battery again to confirm my observation.
Old 04-06-2020, 04:33 PM   #4 (permalink)
Senior Member
Treeman's Avatar
Default
How do you store them?
They should not be stored at full voltage.
__________________
Mike
Reindeer Pass Garden Railroad Supply
Treeman is offline   Reply With Quote Quick reply to this message
Old 04-06-2020, 04:54 PM   #5 (permalink)
Senior Member
Homo Habilis's Avatar
Default
I have 10 Tenergy battery packs of varying mAh capacities. The oldest is from 2013 and the newest is from 2016. I use the Tenergy TLP-4000 Universal 1A Smart Charger.
They are all performing just fine, have not noticed any degradation and none have failed as yet.
Homo Habilis is offline   Reply With Quote Quick reply to this message
Old 04-06-2020, 08:09 PM   #6 (permalink)
Dwight Ennis's Avatar
Default
Lithium-ion batteries begin to degrade from the day they are manufactured. It's just the nature of their battery chemistry. In addition, they lose around 20% of their capacity after 1000 charge cycles. We've all had to replace a cell phone battery, or a laptop battery after using it a while. Nature of the beast.
https://www.popularmechanics.com/tec...-time-6705747/
Dwight Ennis is offline   Reply With Quote Quick reply to this message
Old 04-06-2020, 09:32 PM   #7 (permalink)
Senior Member
Default
The battery pack is inside the locomotive with charger, I just plug in to charge when they are empty.
Old 04-06-2020, 09:34 PM   #8 (permalink)
Senior Member
Default
Agreed, I notice after a few years now, the running time is significantly shorter, estimating about 30% shorter than when the battery was new.
Old 04-06-2020, 09:36 PM   #9 (permalink)
Senior Member
Michael Glavin's Avatar
Default
mymodeltrain<
If you’ll please provide data specific to your care, feedingand use of the failed Li-Ion batteries, collectively we maybe able to offer whatmay have led to the demise of your batteries.
Voltage: 14.8
Capacity: ?
Charger model number and or specifications: ?
Charging frequency/interval: ? (can you estimate total charge/runcycles)
Typical run time(s): ?
Are your loco’s fitted with the same batteries?
Please call out the loco brand/model?
Please describe your typical operation, i.e., charge andrun trains until train stops, run trains with partially charged battery until theystop, stop train prior to depleting batteries???
Please describe how you care for the batteries after arun?
There is a lot of misinformation out there with regard tothe “proper use” and charging demands of said batteries.
Tenergy like all other battery technology resellers, purchases OEM cells and assembles and or packages them as battery packs for resale. Whose OEM cell is utilized is an unknown unless it called out in Tenergy's specifications. Accordingly, all Tenergy packs are not of like origin, quality, age and more. As an example, one 14.8V battery maybe comprised of Panasonic cells while others maybe use Sanyo, LG Chem or others. The quality and shelf life of the cells used to assemble a given run of batteries, together with the careand use of said batteries will dictate its life span.
Michael
Michael Glavin is offline   Reply With Quote Quick reply to this message
Old 04-06-2020, 09:40 PM   #10 (permalink)
Senior Member
Default
Quote:
Wellington
I just installed a new Tenergy battery and the locomotive works fine, again.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
