-   RC/Battery Operations (https://forums.mylargescale.com/40-rc-battery-operations/)
-   -   Information on Rail Pro system wanted (https://forums.mylargescale.com/40-rc-battery-operations/90386-information-rail-pro-system-wanted.html)
Greg Elmassian 04-19-2020 04:51 PM
I'm not considering buying this for myself, but researching it.
The Rail Pro system made an O scale decoder, now labelled O / G... but no mention at all of constant current output, momentary current capability, nor max voltage.
Can anyone give any information?
East Broad Top 04-26-2020 12:30 AM
Not specifically, but I had the chance to run a friend's Rail-Pro-equipped diesel on my dad's railroad last year or the year before that. (I can't remember if it was USA or Aristo--all diesels look alike to a steam guy. ;) ) Ran great, sounded fantastic.
Anyway, you may want to check out the RailPro user's forum: https://rpug.pdc.ca
Later,
K
Greg Elmassian 04-27-2020 04:42 PM
Thanks K, i was interested in sound sync for chuffs in steamers, etc.
The user group will be a good place, especially since it is independent.
zr1rob 06-17-2020 08:52 AM
Hey Greg
I have installed RailPro LM3g units in all my locos (6 so far). I got them from Remote Control Systems of New England. Don Sweet runs the shop, and he is very knowledgeable indeed when it comes to RailPro. I'd give him a call and ask him (603) 321-1347.
I did the install on my locos, I found it a little tedious, but enjoyable. The results are fantastic - operation is excellent, sound is phenomenal and the joy of not having to clean the rails is beyond belief great.
Greg Elmassian 06-17-2020 01:37 PM
Just looked at the manual, no possible chuff input wire.
Don Sweet 07-17-2020 03:47 PM
RailPro Specs
Hi Greg, you are correct there is no chuff trigger wire. The plan is in the next version will activate the purple wire for the chuff input. This will be a software download.
Also the steam sounds will get a upgrade to the UTL files. Most of the diesel and horns have been updated.
The LM-3S-G loco module is rate at 6 amps continuous and 8 amp stall current. The audio amp is rated at 13 watts into 4 ohms and 7.4 watts into 8 ohms. It can be very loud!!
Don Sweet
Greg Elmassian 07-18-2020 07:22 PM
That's a nice spec for the amp, in large scale you can put a pretty big speaker in the loco and bass will use wattage... I actually got a 4.5" speaker in one of my Accucraft tenders...
Dan Pierce 07-19-2020 07:09 AM
Note that visiton Frs7 and Frs8 speakers are available in 4 ohm and 8 ohm versions as are several smaller sizes.
Greg Elmassian 07-20-2020 04:29 PM
Yep, my setup in the USAT PA diesels has 4 speakers, 2 tweeters beaming out the grills behind the cab, and one in the fuel tank, and the other beaming up out the rear fan.
In both cases, used two 4 ohm speakers in series to give 8 ohms to the sound card (2 channel sound from QSI)
https://elmassian.com/images/stories...505_091646.jpg
