On30 Code 83 Diamonds - myLargescale.com > Community > Forums
Reply
LinkBack Thread Tools
Old 10-05-2008, 03:11 PM   #1 (permalink)
Senior Member
Default On30 Code 83 Diamonds
Is there a manufacturer of Code 83 crossings or diamonds? I am starting to hand lay track and using ME Code 83 turnouts but I need a 45 deg and possibly a 30 deg crossing. All I need are the rails pre-soldered, i have a good supply of Mt. Albert O-scale ties.
I do have a 45 deg HO crossing but of course the tie spacing and tie size is wrong for 0n30.
If there isn't a manufacturer is there a website with info on hand-builidng corssings?
Thanks.
__________________
Chief Engineer
Bear Mountain & Pacific
Pete Chimney is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-05-2008, 03:37 PM   #2 (permalink)
Senior Member
DKRickman's Avatar
Default RE: On30 Code 83 Diamonds
I don't know of any, but then again, I don't know much about On30 suppliers. What you could do would be to buy the HO crossing, and replace the ties. Do one track at a time to keep everything in alignment.
__________________
Kenneth Rickman Salisbury, NC
"Never attribute to malice that which is adequately explained by stupidity." - Robert J. Hanlon
DKRickman is offline   Reply With Quote Quick reply to this message
Old 10-05-2008, 05:06 PM   #3 (permalink)
Dwight Ennis's Avatar
Pete - I don't know of any either, but you coul (as Ken says) buy an HO diamond. If I were doing it though, rather than lay one track at a time, I'd replace a few of the ties with PC board ties on the bench. Once those are soldered in place, the'll keep the alignment. This would probably only work on crossings with all metal frogs and guardrails though.
Dwight Ennis is offline   Reply With Quote Quick reply to this message
Old 10-06-2008, 12:22 PM   #4 (permalink)
Senior Member
I will answer my on post - sort of. Here is the website for Fast Tracks. They do sell jigs where one can build a variety of angled crossings or diamonds using code 83 rail. I thought they only sold switch or turnout building templates.
http://www.handlaidtrack.com/on30-cr...c-6_23_191.php
__________________
Chief Engineer
Old 10-06-2008, 03:46 PM   #5 (permalink)
I was going to bring them up Pete, but figured you wouldn't want to go that route. I can tell you that I bought their jigs for #5 and #6 turnouts and have built a few. The first one took me around two hours, but I can now knock them out in under 45 minutes.
Best of all, these are the SMOOTHEST turnouts I have ever seen!!! Pushing a Bachmann On30 flatcar through with my fingers, I can't feel anything - no dropping of the wheels into the flangeways on the frogs, no jogs at the points - absolutely smooth all the way through. I can't imaging any derailments in these turnouts unless the wheels aren't in gauge.
Old 11-12-2008, 11:51 AM   #6 (permalink)
Senior Member
Dwight
I started with On30 ME code 83 turnouts but found they are a bit on the tempremental side. I found the Code 83 rail can easily "pop loose" from the rather small plastic spike heads. I had limited success in getting the rail to re-seat on the plastic ties. I have even resorted to slipping in some Mt Albert O-scale ties and hand spiking the loose rail.
So this weekend I took the plunge and ordered a #4 On30 switch template from Fast Tracks as well as a 45 deg. crossing template. I already have a few hundred feet of ME Code 83 rail. Both templates should arrive by mid-December and I will try my hand at hand-building turnouts. I figure this would be a good way to spend some time off at the holidays and also a way to keep me away from the cookie and candy dish.
__________________
Chief Engineer
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
On30 BUILDINGS bucknutdave On30 Benchwork, Scenery, & Track 25 09-27-2015 04:18 PM
PREMIUM DUAL RAIL CODE 332 OR CODE 250 TRACK BENDER NavyTech Product Reviews 24 08-25-2010 07:31 PM
Code 250 size compared to code 332 Jerry Barnes Track, Trestles, Bridges and Roadbed 53 01-24-2010 03:42 AM
On30 couplers? insanerocketkid On30 Rolling Stock 4 02-12-2009 06:11 PM
One of my On30 bashes railgeek Model Making 4 01-27-2009 07:21 AM
